Store
2112st
Ay Carumba 🙄
Gracias. 😎
May 3, 2024
Ay Carumba 🙄
Moved - you'd put it in macintosh ii, not apple ii
May 3, 2024
2112st
Ay Carumba 🙄
Apple I/II/III
Hope this is the right forum!
May 3, 2024
chrisrueckert
Freshly Recapped Portable - RAM Faults
Thanks, that worked. I'm attaching a picture of the set-up for future generations :-)
May 3, 2024
V
V.Yakob
Bluetooth using D-Link Dongle in OS9?
I tried using this USB adapter, the Apple Wireless Keyboard (Aluminum) (A1314) worked fine on the PM9600. But the boot menu is not...
May 3, 2024
caver01
According to that French page, my D-Link, which is HW revision B3, is already running the appropriate firmware to be detected in HID...
May 3, 2024
Sideburn
Did this isolate where the bad ram is ? I need get my board out again and see if I can fix it.
May 3, 2024
François
The firmware updater seems to have disappeared from Apple’s website, but archive.org has a copy (direct download). It’s in French, but...
May 3, 2024
helmetguy
Toshiba Satellite 480CDT with a bad case of acid reflux
No luck with rejoining traces, unfortunately. I'll have to check the vias a lot more thoroughly than I did at first, then probably get...
May 3, 2024
Radius Rocket & Radius Thunder 24/GT compatible?
I absolutely have the 33MHz version. I added the gold heatsink to the CPU (which is a CPU that has the FPU). I also purchased some...
May 2, 2024
