Store
2112st
Odd PRAM Battery Issue
Well, it should be interesting to see if this issue comes back, once I get the G4's power supply back from Andy's refurbishing service...
May 4, 2024
2112st
Repair Service For G4 MDD Power Supplies
Andy received the power supply Friday, and will start work on it Monday.
May 4, 2024
badferday
Found my Oscilloscope?
You know, I used to scoff at people that put Apple stickers on their stuff, as if it was cringe to do so. Now, I understand. This thing...
May 4, 2024
BlueSCSI v2: Sluggish Performance on SE/30
Kai, thank you very much for your reply! I have two BlueSCSI v2's, both with PICO-W. Each have their own SD card, each card formatted...
May 4, 2024
Sad IIsi chime with no video
Well, the RBV is a good place to start testing continuity - after all, if theres an address or data line that's broken then it has no...
May 4, 2024
Are you using the same SD card in every device, formatted the same way?
May 4, 2024
Hardware
SE/30 owners, if you have a BlueSCSI v2, could you please run MacBench 3.0 "All Disk Tests" and post your scores? (Please use only...
May 4, 2024
MacOfAllTrades
Installing a fan into a Mac Plus
This looks like the Mac got in trouble and was sent to a corner!
May 4, 2024
ComputerCompulsive
Thanks Kai! So would the RBV explain why I get a sad mac death chime if memory is installed? Or would this be just for the video not...
May 4, 2024
May 2024 finds
Mother and child meet for the first time! I drove down to Iowa to pickup this $99 Powermac G3. Quick inspection shows it has a SCSI...
May 4, 2024
T
TheBurgerKing
Mac SE - Gray Screen, no startup sound, no pointer
No startup chime. I have waited about 5 minutes and done ram swaps. I installed 1MB and soldered the resistor. Same issue. The RAM...
May 4, 2024
