Ram 30-pin SIMM socket where to buy?
naruse
52
34
Hello friends!,
So I am in the process of desoldering the ram sockets from a battery bombed SE/30 logic board and I broke one of the ram sockets (and that basically means I will most likely break the other ones; does anyone know where I can buy these sockets :/ ?
This Does Not Compute
Emeritus Board Member
373
534
Looks like something just was goofy with the link, I got it updated:
Reactions: JDW and naruse
dgveedubbus89
19
12
Homestead, FL
Reactions: naruse
naruse
52
34
Colin is still having nightmares from his SE/30 reloaded project (Which came out beautiful BTW) but lucky us we get to enjoy the plethora of information he gathered along the way!
100%; we should put Colin's Sheet somewhere easy to access as it has been proving a quite invaluable resource
Nov 27, 2022
114
I notice that in the spreesheet the cpu crystal is listed as "16.9344MHz, seemingly not available" I have seen through hole oscillators in this frequency available for sale do we know what ppm it requires? Mouser seems to offer between 10 and 150 ppm
Hmm reading the schematic now I see it says 33pF and the closest oscillator I can find says 16.9344MHz 30pf Load tolerance
(link here https://www.mouser.ca/ProductDetail/IQD/LFXTAL003366Bulk?qs=e4/AndAAwgLxw7JTqjIxzQ==).
Is there any way to use this oscillator if your original is damaged and unavailable? Seems like this might be as close as is now available.
2,224
@This Does Not Compute
I checked today and found the price of those 30-pin SIMM sockets to be $9.60 each! Do you remember how expensive were they when you put your spreadsheet together a year ago?
  • Sad
Reactions: naruse
djc6
53
16
Yikes! Even $5 each is quite high, but the current pricing is out of this world.
CayMac vintage has a new solution for replacing expensive SIMM sockets. For a little more than the cost of a replacement socket, you get a memory module with a new, novel way of attaching to the logic board he calls SIPP 2.0:
Reactions: iantm and JDW
373
534
It's likely supply and demand. I've long suspected those sockets are NOS parts, and now that there's increased demand and supply is shrinking, they're going to price them accordingly. Long-term, we'd need someone to bankroll having a manufacturer start making the sockets again -- but given the start-up costs (and likely high MOQ) I'm not sure the pricing for that would be any better.
