PowerBook 1xx USB-C PD Adapter
468
Hi!
I would like to have an adapter for my PowerBooks, especially 180c, 540c, G4 (I have a late 17" G4 that makes the power adapter SUPER hot), and G3 style (I have a 3400 and 1400 that uses the same). Last I checked all my power adapters work but hunting them down and dealing especially with the 500 series is not something I am looking forward to dealing with. What would be an all-in price?
The 180 requires a buck converter to knock the voltage down to 7.5v, but I've used 20v adapters with my g4 and G3s with no issues, so you could get those a bit cheaper since they just require the USB trigger board. I think the USB trigger boards are ~$3 each, the cables are a usually $3 or so each, and the iBook G3 adapter it $7 + shipping, but unfortunately the store where I got mine seems to no longer have stock.
So, for the 180, you'd have a buck converter ($2) and the USB-C trigger board ($3), and the standard power 5.5mmx.2.5mm jack ($3).
For the G4 adapter, I'd recommend a boost converter ($2) and the USB-C trigger board ($3) and a 2.5mm headphone jack for the power plug ($4)
For the G3/3400/1400, I could build you an adapter that you'd just could get one of the C11 adapters to make it work when they come back in stock, or if you have a bad charger I could try to harvest the connector from, I could wire it up. It would be the USB-trigger board ($3) and a standard 5.5mmx2.5mm jack ($3).
For the PB5xx, it would be a 15v USB-C trigger board ($3) and one of my 3d printed, custom assembled cables ($8). Note that my PB5xx adapters only power the laptop and do not charge the battery because the battery requires a separate 16v, current limited supply so I connected only the pins for powering the laptop.
That would be 4 adapters. I'd use my own printer to print the cases for $6 for all 4, but if you wanted the higher quality resin prints, that would likely run $20 for all 4.
So, with PLA, some printed cases, you'd be looking at around $40 + shipping, With the nicer resin cases, it would be $54 + shipping.
EDIT: I just checked my 20v adapter with my 17" G4 and it seems that my position of "20v is fine!" may not hold on the larger powerbooks. It did work with my 24v adapter, so I'd recommend adding $2 for the boost converter for the G4 adapter. I updated my recommendation and cost above.
PacNPal
I'd take the $54 + shipping option. If you're willing to do it, I'll happily pay.
468
Sure. They’re relatively quick to assemble.
DM me and we can hash out the details and I can get the resin cases ordered and any parts I don’t already have on hand.
468
Are you willing to build a 520c adapter? If so I am interested.
Yeah, I think I have some with the resin custom connectors. I’ll have to add up my costs. Feel free to DM me.
Also, note that the PB5xx chargers had two independent 16v power supplies. With these you only have one. So it will run the machine but not charge the battery.
