Disk Jockey v4 for macOS is out
OneGeekArmy
263
Belgium
diskjockey.onegeekarmy.eu
A better interface, a brand new Inspector for your files, support for more formats (NDIF, UCSD Pascal, Atari ST hard drives and more).
See your files' data as hex, preview their contents when possible (for example: read your AppleSoft Basic listings directly or check out Atari ST images in Degas format).
It still runs on Mac OS 10.13 and up (many bug fixes for the older versions) and it's still free.
The release notes are here: https://diskjockey.onegeekarmy.eu/files/diskjockey/Disk-Jockey.app.html
Phew. I need a nap.
@JDW : This version parses the Apple II images you provided me with a few months ago. Some of them were in the UCSD Pascal format and it's now supported.
JustG
59
14
California
Thank you for continuing to build this for older OS versions! I like to compartmentalize my interests between modern computers and the one I mainly use to support my old computers runs 10.14.
Reactions: OneGeekArmy
OneGeekArmy
263
Belgium
My goal is to try and support older Macs as long as possible (which I think makes sense for an application aimed at retro enthusiasts).
I'm not sure how long the inevitable march of progress (and, let's face it, Apple) will let me do this before my development toolchain no longer lets me do it. But as long as it does, 10.13 will remain the target.
(Especially since I finally have a working 10.13 machine for testing :) )
Elosha
Europe
I really like the new version, and as already said elsewhere, thanks for keeping up support for "old" host OSes. (Keeping High Sierra around for 32bit Support and EFI experiments.)
However, it still believes all of my FAT12-Floppies (MS-DOS, NT, firmwares like ARC, EISA etc.) were Atari ST. And while the infotext claims they would be not exactly the same as MS-DOS-formatted disks, it can´t differentiate the formats. ;) As many retro people also like MS-DOS, I personally expected it should be able to either differentiate or be more generic when it comes to FAT12. Are there any plans?
Reactions: JDW and OneGeekArmy
OneGeekArmy
263
Belgium
OMG what an oversight on my part :) Apologies for that.
Would you mind zipping up floppy images from a couple of different platforms that support FAT12 and sending them my way? Non-DOS preferably so I can spot the eventual differences.
I'll see what I can do ;)
Reactions: Elosha and JDW
Elosha
Europe
@OneGeekArmy I will, but probably easiest would be to
a) Rather detect the ATARI OEM signature "Loader". Because PCs would use OEM signatures "MSDOS", "PCDOS", "SYSLINUX", "VGACP", "MSWIN4" or others + version numbers … plus accidents like "G8q3IHC" ("xxxxxIHC") that result in mangling by 32bit Windows. Even my Alpha FW Update and EISA ECU Diskettes use "MSDOS" for compability.
As this is complicated …
b) Just switch by extension, use ATARI if the ending is ".st", as the others could be ".img" or ".imd" or ".vcp" or ".dd" ;)
Anyway thanks for listening to these ideas :)
OneGeekArmy
263
Belgium
The (completely self-imposed) constraint regarding file extensions is that I don't want to use them as an indicator of the file type. They are unreliable (people can change them at will) and, once you start supporting formats coming from different systems, they name clash (an ".img" is different on a PC or on a Mac and, on the ST and others, it's a picture format :) ).
As for signatures, "Loader" only appears on bootable ST floppies so that's not sufficient. It's a bit of a pickle.
But I'll figure out something eventually :)
