2009 Mac Pro 5,1 Odd Power Problem
mastanhope
Mount Wolf, PA
So... nobody in my normal circle has been able to figure out what is ailing my ancient Mac Pro, so allow me to pick your brains!
I have a 4,1 > 5,1 Upgraded Mac Pro that I use as my daily driver. Works fine, no issues in general except one pesky power issue.
Ever since upgrading to Sequoia, if I walk away from my Pro without logging off, it will do a HARD shutdown. It shuts down so hard that I can't even turn it on with the power button, I have to physically unplug the machine, and plug it back in and then it will come back on with no issues.
As long as I am using the computer, doesn't matter what I am doing, it works fine. No issues at all. I can sit in front of it all day and do whatever I want, it will not shut down or do anything out of the ordinary. If I log out of the computer back to a login prompt, it will never power off, and will run happily until its told to sleep or power off by me. It only happens when I am logged in and the computer is sitting idle. If I leave a Youtube video playing in the background, it will not power off. It is the oddest behavior I have ever witnessed on a computer of any kind.
I posted specs of my machine, I can give more information if needed, im just stumped. This issue only started once I installed Sequoia on the machine. I ran Big Sur before this with no issues whatsoever. The machine specs haven't changed much except I did install a dual processor tray and more RAM in the machine, but again, I did that under Big Sur and no issues with it for months until I upgraded to Sequoia.
Michael
527
Since you say if you leave a youtube playing it will not crash, I am guessing it has something to do with one of the sleep states of the CPU. I don't know the underlying issue or change that happened in Sequoia. My daily driver is an iMac12,2 and I have no issues except sleep. This is because I replaced the CPU with a Xeon that does not support sleep. If it sleeps, it crashes. So, I let it run 24/7 and just have a hot corner to lock screen (no screen saver, no auto lock, no sleep). I have disabled all sleep. Granted that a MacPro has Xeon processors, and somehow Apple has them support sleep, I don't know if this is the correct rabbit hole to follow. Just a wild guess at this point.
Other reference from Apple forums.
Also, since you are running Sequoia, I assume you are using OCLP or OpenCore. Maybe sleep is misconfigured?
mastanhope
Mount Wolf, PA
Running the latest OCLP on here. Sleep works perfectly, amazingly. I can put it to sleep, and it wakes just fine. I have autosleep turned off thinking that was one of the issues, but it still persists.
I turned everything off in terminal:
mastanhope@Christine-2 ~ % sudo pmset autopoweroff 0
Password:
mastanhope@Christine-2 ~ % sudo pmset powernap 0
mastanhope@Christine-2 ~ % sudo pmset standby 0
mastanhope@Christine-2 ~ % sudo pmset proximitywake 0
mastanhope@Christine-2 ~ % sudo pmset tcpkeepalive 0
Warning: This option disables TCP Keep Alive mechanism when sytem is sleeping. This will result in some critical features like 'Find My Mac' not to function properly.
now I will see what happens. If it doesn't shut down, then I know something above is the culprit, and I can just have a script run that disables everything. I'm not worried about power savings as the machine runs 24/7 anyway, I only sleep it when I won't use it for more than a day (which is rare).
mastanhope
Mount Wolf, PA
That didn't do the trick either. I locked the screen, and went out for about 2 hours, and the machine was on, later, i locked the screen and it shut down after about 3 minutes. Back to the drawing board...
