6500 Heatsink Upgrade Question
Jhogs
Hello Tinker Different!
I'm working on a Takky Upgrade to a Color Classic, but I thought I'd post in this forum because my question concerns the PowerPC 6500 300mhz Logic Board that I'm using.
I got the logic board off of ebay and it looked to be in good shape, but the heatsink fan combo was pretty gross and I wanted to add more thermal paste. Unfortunately, I broke it taking it out and need to replace it. I'd like to swap in something beefier anyway, since inside the small Color Classic shell there will be a lot less airflow than in the tower this logic board is supposed to be in.
Any advice for me on what modern solution might be best for this 30 year old board? I was going to just buy a 40mm aluminum heatsink and 40mm 12v Noctua fan and zip tie them through the holes that the metal clips used to go into, but I'm interested to know if any of you have a better idea.
I'll be excited to share pictures of the Takky up and running once it's complete!
Arbystpossum
78
50
USA
I have a 225Mhz one, and I took the heatsink off of a dead 6360 board and put a fan in the center of it, it works extremely well. Anything you put on there will be better than what was on there from the factory. Beware, PCI cards will decrease proper airflow.
