PM 7200 doesn't see CDs, but boots up from them
Star Explorer
This happened once 2 or 3 years ago, and I read somewhere that if you put a space before an extension filename like " Apple CD-ROM", it will load the extension sooner in the boot process, but I can't find that source anymore. It fixed it last time, but it's not doing the trick this time.
I just installed Mac OS 7.6.1 a couple days ago. I've also read of other people having strange problems with the 7200.
Another weird thing that happens is sometimes the computer will corrupt the desktop pattern prefs file, and the pictures look all messed up. It also affects the scrollbars and the titlebars. If I delete the desktop pattern prefs file, it fixes it next bootup.
I can't figure out any setting or configuration that will fix the no CD problem.
Any help would be greatly appreciated, so that I can fix it in the future when it happens again. Thank you
jibsaramnim
39
26
South Korea
davejansen.com
Is this with an original Apple CD-ROM drive, or a third party replacement by any chance? I might be way off the mark here, but this sounds very similar to how things work when using external third party drives that require a patched extension to work, so I thought I'd mention it just in case.
Star Explorer
The only thing on the SCSI bus right now is the CD-ROM. I have a Sonnet Tempo Trio installed, which I run my hard disk on. Now it isn't even booting from the CD drive. I literally have spent a week on this computer. I just wish it would stay consistent. It's always doing random weird crap. It's more unpredictable than predictable.
The CD drive has done this before, but snapped out of it. I used to think it was a bad CD drive, but when I put the space before the extension filename back then, loading the extension earlier fixed it. But even in Mac OS 9.1, it does weird things sometimes.
@jibsaramnim it's the one that came with it, so an Apple drive. That's really interesting! I never heard of a patched CD-ROM driver before. What would just all of a sudden cause it to do this? Sure the drive might be physically bad, but it only started not being able to read CDs within the last day or today, because like I said, I installed 7.6.1 2 days ago. I'll try that, thanks.
428
Make sure it's got an Apple logo on it and then make sure the drive is terminated properly if it's the only thing on the bus.
edit: redundancy elimination
428
Yep, the hard drive's terminated, the optical's not. If you want to eliminate the HDD, you'll need something like this in its place:
IDC50M SCSI Terminator
Volvo242GT
399
233
Currently Duvall, WA
Or, install termination resistors onto the board of the CD-ROM drive. I forget if the Panasonic tray loaders have the terminals for them, but I do know that the Sony caddy loaders do, next to the 50-pin connector.
Star Explorer
At first, like a day or two before I installed it the latest time (I reinstalled it again since then), I had to put on two or three jumpers. After I did that, and closed TE, it worked. But that was on a different computer. When I confirmed everything was good with that hard disk, then I reconnected it to my 7200, and it was able to read CDs again. You guys were right. It was a termination issue.
