[Discussion] Use of AI/LLM in the retro community
2,099
This is a hot topic so please be respectful - you can have positive and/or negative opinions about it but there is no reason to personally attack or be rude to someone who has a different opinion.
There have been quite a few projects lately that have been either fully or partially done by an AI/LLM in the retro community - it seems that trend is only increasing.
What do you think about the use of LLM/AI for retro projects?
2,099
I'll kick it off:
My opinions of LLM/AI have changed quite a bit over time (and likely will keep changing). I both think it's an amazing technical achievement and it's advancements in it's ability to code especially have been a boon for productivity of software developers. On the other hand it seems it could cause the downfall of civilization.
Linus Torvalds had a few interesting takes on LLM usage, to paraphrase two I can recall (I'm trying to find the video) : Cat's out of the bag and it's not going back. It's similar to when compilers came around and developers no longer needed to write ASM.
LLM/AI currently only work (well) when the user knows or can evaluate the answer that is given. If you ask it a question you don't know and it gives you the wrong answer and you don't know how to evaluate if it's true or not - then it's abosolutly useless.
I kind of liken it to someone using an axe to cut down a tree vs. a chain saw to cut down a tree - both will cut down a tree, one will take a lot longer. If you don't know how to use either you'll still be faster with a chainsaw but you also might cut off your leg or fall the tree on your house.
RE In retro - Learning ANSI-C or ASM is fun and intersting - but then you actually want to learn that for some result/app/etc. If you never grew up with that gaining a life time of experiance isnt feasable for a small hobby. I personally don't mind if a project is done with an LLM if it's useful and works.
One thing to note too is that I've seen some vibe coded paid for retro software. While that is their choice the barrier to entry is so low now that your paid vibe coded software could be vibe coded by someone else in an afternoon as well. It's really an intersting time where the barrier to entry is almost zero. I'm not sure what that will mean for the future.
Of course this space is changing almost daily so my opinions can/have/will change.
2,099
This is a pretty interesting use of an LLM on a G4 (and maybe even Mac Plus?!)
I Put Modern LLMs on a 2002 Macintosh - No Internet Required
On a hypothetical Mac Plus: AltiVec OFF, FPU OFF (SANE), 2MB arena, single-layer paging, 64-token KV cache, Tiny model only.
Reactions: wottle
MacOfAllTrades
214
237
Thanks for starting the discussion in a post!
Full disclosure - I recently spent a few weeks porting open sourced linux doom over to System 7 specifically targeting the SE/30 . Community has been generally positive. A few negative responses over in a thread on 68kmla related to AI’s use in making it. It’s my first time using AI (in this case claude code) to help make a vintage mac app, and have made vintage mac apps before.
Opinions follow:
## Trusting AI-generated code
Inherently, anything AI-generated is less trustable than something human-created. Not because AI necessarily produces worse code than average humans (it may or may not) but because the kinds of mistakes that AI makes (be it in pictures, algorithms, logic, code, bugfixes) are simply different than the mistakes humans make.
So if this matters in the application - strange failure modes might be unacceptable. Take two examples:
  1. A System 7 application that is a game (let’s say Doom)
    If there are weird failure modes made in the AI’s code that are unexpected and unlikely, compared to human code, it’s probably alright. I know of no one using Doom to make safety-critical decisions or workflows such that it is paramount to comprehend and control fail cases such that AI-induced failures would be of major concern
  2. A self-flying plane codebase
    Clearly a safety critical application. The stakes for failure are tremendous. The safety argument for the overall system is underpinned with safety analyses that include things like fault trees and hazard + risk analysis, etc. Basically — understanding and mitigating failure modes (be it from the software or otherwise) is a must for being able to maintain and justify the safety of the system.
My point is that you certainly *require* trust in the code in #2 and you *do not require* trust in the code in #1. Therefore the bar to acceptability of AI code is much lower in 1 than in 2. But it’s about software and the safety-criticality of the appplication that makes the difference. And I’m not saying you can’t have item #2 with AI code in it - but you’d want to do a lot more than vibe code that’s for sure.
Rounding back to our Hobby of retro tech - The whole thing is pretty much full of non-safety-critical applications (think like #1 above).
Ok so that’s trust.. what else matters in our hobby?
## Code accessibility
Another thing that AI induces is a “Comprehension Debt” by its developers. So if not handled well, the developer(s) of a project will quickly lose touch with understanding how it is all the code they are pumping out works — innate system insights are lost or never developed — and being able to make changes becomes harder and harder as this Comprehension debt expands. Take Doom-SE/30 — Of the code that was changed beyond the initial linux-doom it was based on, I wrote maybe 1% of it by hand. The rest was done by Claude’s models. If it matters, and I think it does, the 99% written by claude was “managed” by me. It wasn’t just “go” and come back in 14 hours to find the game baked to where it is now. There were issues, bugs, plans, fails, iterations, arguments with the model, etc. I do not claim that this makes up for the Comprehension Debt but it is different than “go” and hitting publish.
But back to code accessibility — in so much as a retro tech project hopes to-, expects to-, or ultimately benefits from- community handoff and contributions now or in the future — it would certainly behove the codebase to be understandable because the first step to extending it later (especially by others) depends on the codebase being accessible, or rather “comprehensible.” So if AI-built code incurs a comprehension debt, and when there is hope or desire for the code to be carried forward by the community in the future (or heck even by the original author after they’ve forgotten key details) then there is benefit in the produced code to be comprehensible.
A point here is that there are TONS of software products that do not have any source code available but whose value is still high. I don’t have the source code to SimpleText, but I’m glad the program is there and I get a ton of value from it. Same could be said about the vast majority of programs we use for our retro hobby - if for no other reason than because most of what we use is old closed-source products. Put another way - What’s the difference between:
  • High-comprehension-debt AI-based apps for our retro machines that work
  • Low-comprehension-debt based apps for our retro machines that work
Yes, one is ultimately better than the other in absolute terms. But if they both work —is the typical hobbyist going to sit around saying “I’m so glad the one I’m using exhibited low comprehension debt by its authors” ??
Don’t get me wrong — there are _certainly_ examples of open-source projects in retro tech communities where comprehension debt and accessibility to the code DO MATTER. For example - the BlueSCSI project, itself a fork of the ZuluSCSI project, is a community-supported endeavor. Here I’d say it’s extremely important that Comprehension Debt be managed (AI-induced or otherwise). And using AI tools to “vibe code” (for lack of better term meaning using AI coding in a way that produces high-comprehension-debt in the code produced) this sort of project comes at great risk because that debt will work against the broader effort and advancement of the project medium- and long-term.
Key question others might know: How are big famous open-source projects managing coding contributions when it comes to AI-assisted changes? How’s Linus Trovalds handling it with the open sourced parts of linux? He’s still the big MR approver on major changes…. Maybe someone here knows? Or @eric how would you look at submissions to BlueSCSI repo that are AI-assisted? Have you set guidelines? More curious - not saying that you should or shouldn’t.
## Other relevant considerations (I assume no right/wrong stance on these, but they might feed thought and conversation)
  1. Alternate workflow and mindset frameworks for considering AI-assisted retro community code
    1. Given the documentation I produced and included in Doom-SE/30 (see PERFORMANCE_IDEAS.md and OPTIMIZATION_HISTORY.md and the Source Code and Port manual file) one could argue that the real value of the project long term is in having these records of HOW the port was done, WHAT optimizations were tried and their results, and FUTURE WORK. In many ways it strikes me like a research article in academia. It didn’t productize the work, but it did present the results of enough prototyping to get it working. Someone could look at it, and the codebase, and the docs I cited, and advance it. Heck with the codebase and those documents someone could go and re-implement the optimizations by hand in (hopefully) a more efficient way (better sw performance) as well as in a way resolving the AI trust/comprehension issues. Or in 30 years they could just feed that info as part of the information prep for re-doing the port from scratch (with or without AI).
      Does providing that extra documentation help make things better? I provided it for both that reason and in order to just keep a record of what I tried. AI is not intelligent and having records helps keep it in check when it forgets what was done in the past.
  2. The “Who cares, if it works?” mindset
    1. If you always wanted Mario on your Atari, and no one ever made it, and you can make it and do so with the help of AI --
      How much more really matters? (possible answers follow - none do I claim to be my position)
      1. We don’t want AI-slop programs in the retro tech community, so even if it gets us programs and functions we’ve wanted and didn’t have, I’d rather not have them if it risks or has AI issues
      2. I’m glad to have it at the cost/risk of AI-induced issues, but I want it treated “different” somehow in the community. Maybe it’s a naming convention, maybe its that its collected differently in sites like `macintoshgarden.org` so we know it’s AI “tainted” somehow.
      3. Nothing else matters — we had no Mario on Atari, and now it’s here - yay.
    2. Note that the subbullet 2 above is interesting but brings loads of concerns. Who governs this / decides when something has “enough” AI to count? Who enforces this? What about folks who lie or just don’t tell people that they used AI?
Anyway - this post is long enough but I was excited at the prospect of this sort of convo in our community. It’s a conversation that should happen throughout not only coding industries/communities but throughout society. So if you’re in this convo and have something to say - welcome - and note that you’re thinking about questions that the entire human race has to ponder and act on. Pretty cool to be part of something that large and important.
XodiumLabs
74
141
South Bay Area, CA
xodium.net
Personally, I'm one of those people who run to retro tech to *escape* the woes of modern tech and what AI is currently doing to it, so on one hand I'm not really a fan of bringing it to retro tech projects. It's kinda like moving to avoid your ex and they end up just moving to where you moved to in an attempt to put some distance between them.
I do understand AIs help with some retro tech coding things, but to put it in the words of a friend of mine...it's like, uh, certain explicit things you can do to yourself. Great if that floats your boat, but I would prefer not to hear about it. Tell me about what YOU did with YOUR project, don't ell me about how Claude is so awesome for helping you out.
That said I do think AI is great at some things, and generally running local models on devices you own is relatively harmless and that I don't really care about. But trying to welcome the big LLMs like ChatGPT and Claude and such into our hobby and let them run rampant? Eh. My opinion lands more in "could we not, please?"
I also did write something on my own site about how I view AI stuff, if you want to read that.
Trekintosh
Ai image generation has absolutely no place, full stop. Code has a measurable input and output. While there is an artistry to making it, at the end of the day, you can measure if it works or doesn’t works. (Personally I resent AI code writing entirely, but I can at least *see* an argument for it).
image generation, on the other hand, is entirely repugnant. Visual arts are *not* measurable. Any time you slop out a logo or album cover or what have you, you’re taking effort and joy directly from a human experience. I would unironically prefer MacPaint scribbles to any kind of slop image. “But it’s a placeholder!” So is scribbles and they’re not going to be accidentally left in.
If you need art and really don’t want to do it yourself, try Fiverr or just asking around. Theres tons of artists basically idling at all times who will sell their work for dirt cheap.
as for writing, like your “sell sheet” for your project etc? I can’t really say you’re taking money out of an artist’s hands because it’s just you, however, I hate the vibe of slop text. It’s like having a Microsoft apology letter whispering directly into your brain, so I prefer not to see it.
P.S.: if you say you “put ChatGPT on a retro computer” and it’s just a web portal, you should feel bad. Go whole hog like the video above, or be honest.
Reactions: Volvo242GT
alexhoopes
Awesome to see my project shown here, thank you so much!
While I used to not really care for AI, my mind changed when I was working an IT job at a large company and they got into how companies are really looking for AI knowledgeable engineers and how over the next few years it’ll be a vital skill to have in the work field. I wrote my first program when I was working as lab technician at Intel, automating server deployments and registration to our software and I’ve been extremely interested in becoming an engineer since. Programming kinda just clicked for me after I taught myself it (2020, before the AI takeover lol) using YouTube, reading documentation, and asking questions on StackOverflow.
I recently moved out of state and have been looking for a job, and as IT jobs haven’t landed so far, I’ve wanted to go full force into applying for an engineering job somewhere.
I know that as you said AI is very controversial in this space and I was a little worried about how the community would react to my program but as I’m 23 with no degree, I needed a solid portfolio piece though. Knowing how much AI matters to modern companies, I knew this would be a headturner for recruiters and would be a great interview talking piece. Going to update my resume and start applying for jobs this week and see what happens :)
Again, thanks for the share. Very cool to see what I made posted on a forum I visit and learn a lot from.
This community rocks!
MacOfAllTrades
214
237
This thread is the mode of folks sharing their opinions openly right now -which is great. Keep ‘em comin’!
More food for thought:
# Analogies
## Programming Analogies
- **Compilers replacing assembly** — moved developers up a level of abstraction
- **IDE/autocomplete evolution** — context-aware suggestions vs. basic completion
- **Calculator for mathematicians** — handles tedious work, frees focus for higher-level problems
- **Integrated Stack Overflow** — instant solutions without context-switching
The key thinking point on all of the above is that the more you had to do with the code you are producing (or verifying etc) the more you learn about it and any system it fits into and losing this is a detriment to everything except short-term time-to-delivery. But yet I don’t think the hit in knowing assembly has greatly set back the mass of programmers in the last 30+ years. I’ve written assembly - but it’s not a skill I polish often and it’s certainly not a skill where proficiency would likely translate into better results overall — Namely that the rate of code production would suffer so greatly that any gains in performance would be outweighed. Furthermore, it’d be a setback in portability / reusability of the code. You can’t do (or it’d be way harder to do) certain things in Assembly that you can do with fancy C/C++ mechanisms. So things many programmers gets from shared libraries and that sort of portable generic code would be diminished or lost if we all wrote in assembly.
## Non-Programming Analogies
- **GPS for navigation** — guides the route but you choose the destination — The skill of knowing your streets and routes has long become endangered since GPS turn-by-turn nav became commonplace. I am impresed when I meet someone who is still on top of this skill but it’s one that I’m willing to mostly let catch dust in my personal toolbox.
- **Power tools in construction** — amplifies capability while requiring skill and judgment. Def have more artisinal respect for a woodworker who made a furniture piece without power tools. But I don’t hold the value highly that we all should strive for hand-made hand-tool-only furniture nor that there is more utility in such furniture. In fact a mass-produced piece of furniture probably can help more people than a fancy expensive hand-tool-only one does so I think it’s value to society is greater. But I certainly think a fine hand-tool-only piece of furniture is ’nicer.’
- **Spell-checker for writing** — catches errors but doesn't create the content so it’s not the same capability. But I def. don’t assume people’s innate spelling capability is represented in an email or text because autocorrect and spell checking exists. And quite frankly when I do see misspellings in such informal writing I assume it’s from fast typing on a keyboard and not representative of their intelligence. Now if it shows up in a Legal Brief or filing then I do think the person is less-capable etc.
- **Photoshop for image editing** - Changed the game on what graphics artists could do and how long it would take. But now we rarely think “Oh they used photoshop before publishing that picture!!!?!?!?”
- **HDR on Photography** - I was at an art fair and saw some cool canvas-printed photography works. I asked if they used a computer to enhance it and they sheepishly admitted they did (HDR/saturation adjustments, etc etc etc). It did make me think it somehow meant less photography talent.
#Exercises
## Quality & Trust Exercises
- **The authorship reveal** — your favorite program was 80% AI-written; does this change your perception of its quality or reliability? Short answer for me: Yes. I’d lose trust in it because I’d assume that it was less-likely to be verified thoroughly and less-likely to have had its issues observed. Whether I _care_ about this perception change depends on whether I needed quality / reliability and how much out of the particular program. Note this aspect is what makes me skeptical when I hear “stocks are falling in traditional software companies because people expect AI to displace their products” — I don’t see it happening with the current AI capabilities and business dependence and need for reliability in the enterprise-grade products they spend big money on. EXAMPLE: I don’t think CNN will cancel their subscription to Microsoft365 because they hired an engineer that used AI to make a suite of Office-like programs for CNN to use from now on. I just don’t see companies taking that risk -
## Skill & Learning Exercises
- **The explanation challenge** — AI generates a solution you don't fully understand; do you ship it, study it first, or rewrite it? — I’d say depends again on what it might be used for. Safety-critical: Hell no you don’t ship it. Campy personal project - Up to you. With infinite time - definitely study it. Enterprise-grade product where maybe it’s not safety-critical but you’ve got large contracts on the software with customers - you definitely don’t ship it.
## Value & Craft Exercises
- **The creative contribution question** — what percentage of "your" code can be AI-generated before it stops feeling like your work? Very interesting question — I’d extend this further out — how far removed can you be from the coding of a software product before you can’t claim a primary role in its creation? This happens all the time with “<such and such> is the father/mother of <some product>”.
- DeLorean was the father of the Pontiac GTO
- Steve Jobs created the Macintosh (/iPhone / iPad / Apple I, Apple ][)
We already have a societal track record of accepting crediting project- / team-/ company- leads as the ‘creators’ of them.
So if you said “Bob used Claude’s artificial intelligence when he made his new program” it’s somehow less valid (in terms of assigning the credit to Bob) than when you say “Steve used Andy Hertzfeld’s actual intelligence when he made the Macintosh” (something we all know but regardless accept when Steve is broadly credited with making the Macintosh).
- **The craft vs. output dilemma** — do you value the process of writing code, or only the end result of working software? This has lots of human psychology in it, too. It’s part of “well they found a way to sweat less to get this done, so I don’t want to give them as much credit.” Certainly I agree that if it’s cheaper to make something, then that ought properly impact the market (i.e. reduce its final cost to the consumer) but I don’t give a BMW model less credit if between this year and next year they find a way to turn a step in the factory from requiring human assembly to becoming robot-assembled.).
2,099
I've not heard this term but articulates a lot of what I've seen and experienced.
Something similar is that if someone pointed an LLM at BlueSCSI's source and said "Convert this to rust and run it on an esp32" - it probably could do it - but if that person didn't know much about what SCSI is and how it works, that debit would catch up to them pretty quick.
The volume of PR's is small and not worth it (currently) to make it a policy. If the code works, is solving and issue, is understandable by the submitter and maintainers, and follows SCSI standards I'm fine with it. If it's a huge feature that doesn't take into account other features and would add debit to the project probably not.
One aspect of the BlueSCSI project where an LLM has been annoying is users asking LLM's questions and feeding questions and answers from support sessions into LLM's and they are not drawing the right conclusions. I've debugged 1000's of SCSI problems and the LLM's just don't have that knowledge to catch issues. I'm always polite but ask the user to just let me help them, it'll go faster.
Also thanks for the on topic and thoughtful discussions - I haven't read through them all yet but will later tonight.
Reactions: MacOfAllTrades
SitesOnFire
I'm a Java/Typescript dev in my day job, who is beginning to program on a Macintosh Classic. Alongside having read several old Mac programming books, I've made use of AI to help me learn the Macintosh toolbox and ANSI C in general. Just like modern code, the answers AI gives me and it's contextual understanding, are not great. But asking it questions like how something I'm used to in Java works in C, has been great. While I could have not used it at all, and just read books/ Think C reference etc, I have very limited spare time to devote to retro programming. Leveraging AI to help me up skill lets me focus on just having fun coding rather than grinding through. Since this is a hobby for most of us, I don't see much of an issue with people using AI to help them.
XodiumLabs
74
141
South Bay Area, CA
xodium.net
There is another component to my disdain for AI that I forgot to add earlier...seeing as I'm sort of known in some circles for doing a thing with SATA, AI has been responsible for project costs ballooning for me because a cheapo 128GB SSD that I got for all of $13 last year is now triple the price. And as someone who has the unfortunate affliction of being really into mid-00s PC/Mac hardware, I feel like I'm getting pinched from both ends because that stuff is starting to go up in value so if I need something for a project, the prices are high because OMG rare steve ballmer or AI is driving up the costs of SATA drives that I use.
Even for more modern projects the costs of SATA spinners has gone up significantly, too. It's friggin' nuts.
Which is why I'm more a fan of like, locally-run models and the like, not a fan of welcoming Big AI into our hobby when it's already kinda ruining it from my PoV by driving up costs for drive replacements (meaning the only way to keep it price effective is to buy lots of SSDs that have already been beat to crap and hope they keep working until prices come back down).
KennyPowers
331
366
I honestly don't understand this distinction. A piece of software "works" if it functions in the way its creator(s) envisioned...if it satisfies requirements...if it "is" the thing that was desired. Likewise, if someone needs a post-impressionist-style digital image of a skydiving cat, they can determine if an image, however it comes to exist, meets those requirements. It should also be noted that, in both mediums, it has long been common for requirements to be set by people without the ability to personally implement them...until a new tool comes along. The advent of ubiquitously available BASIC allowed a lot of people to create useful software for themselves that would have otherwise needed to provide a spec to a hired programmer. Software has also historically improved the quality of images, graphics, and publications producible by users without "traditional" visual arts talents.
It seems to me like LLMs as a *tool* can be misused just as easily whether you're generating code or pixels. If you blindly trust it, either due to laziness or incompetence, then the output is likely to be bad. I agree that this happens a *lot*...it's a shiny new hammer and all of a sudden everyone fancies themselves a carpenter and everything's a nail. Still, nobody can deny that LLMs can facilitate productivity gains when used "correctly". Also, I can use a *tool* like Illustrator, or a high-level programming language, poorly and produce subpar digital images or software too. The acceptable sophistication of the tool seems a little arbitrary. 50 years from now, will we have an organized group of "digital Amish" who only use technology that existed before 2022? Maybe that's a dumb question on a vintage tech forum 😆
I agree that an image generated wholly by prompting an LLM isn't "art", but that's because I think art is just as much the process as the product. I even occasionally enjoy coding purely for the process too! When I'm experiencing someone's art, a large part of that experience is thinking about the work and creativity that went into creating it. Personally, a substantial human element is necessary for me to appreciate something on an artistic level, and someone's ChatGPT chat log just isn't a compelling experience to me. The availability of LLM-generated images doesn't prevent anyone from continuing to enjoy the creative process, nor does it prevent art lovers from appreciating everything the artist put into their work. However, sometimes an appreciable artistic experience isn't in the requirements. Sometimes you just need a meaningless picture of a skydiving cat, and that's ok IMO. One doesn't replace the other because they're different things that serve different purposes.
PS: I know I didn't mention the ethical questions around how most commercial LLMs were trained, as I'm honestly not sure how I feel about that. Some people compare training on copyrighted materials or code with certain licensing requirements to how a human would be influenced by those stimuli, but that gives these fancy word predictors a little more agency than I'm comfortable with (or are our brains just really REALLY good at predicting the next link in a chain of sensible stimuli responses too?). Regardless, the genie is clearly out of the bottle.
Reactions: eric
KennyPowers
331
366
As someone who just today had to purchase a replacement spinner for a failing drive in my NAS, I also loath the effect the AI arms race is having on the availability of certain components.
2,099
Local LLM's are 1-2 years at best behind what commercial ones are offering - I don't think anyone can do much besides some inference or classifications locally. I have a 128GB M3 and it can hardly run many of the "good" local LLM's and is extremely slow at it.
I agree that I don't see the distinction on art - even fiver's guidelines say sellers can use AI and only need to disclose if the client asks. Art is in the eye of the beholder - I really want to see this skydiving cat now! My initial comment still applies - it can either be a great tool or destroy civilization with deep fakes, etc.
Buying a gaming PC recently I did get a steal on RAM at current prices - $200 for 32gb of DDR5 - probably slow timings than $200 would have got a year ago but it meets my needs. I read recently that RAM manufacturers are not building new capacity as they think the AI bubble will burst before they can get new capacity online (years) - which also inflates prices. And yes my NAS only has 6tb free... not looking forward to buying a new HDD.
RE: Linus's recent thoughts - it was from clips of this video at a recent summit (Used Gemini summary to search for timestamps/summary, but have watched the clips from it):
  • AI on GPUs and Vendor Relationship: (11:13 - 15:04) Linus discusses how AI has shifted hardware spotlight away from general-purpose CPUs and accelerated Nvidia's engagement as a better player in the Linux kernel space, specifically regarding resource management and virtual memory.
  • AI in Code Review and Infrastructure: (15:35 - 17:43) He discusses using AI to help maintainers manage patch flow and backporting, while also mentioning the negative impact of AI crawlers on the kernel.org infrastructure.
  • AI Generated Bugs and Security Reports: (17:43 - 18:03) He touches on the issue of AI being misused to generate fake bug reports and security notices, which wastes maintainer resources.
  • AI for Code Generation and 'Vibe Coding': (18:04 - 23:55) Linus gives his thoughts on vibe coding, suggesting it is a good way to get new people excited about programming, even if it is not suitable for complex maintenance. He compares AI to the transition from assembly language to compilers, viewing it as another tool to increase productivity rather than a replacement for programmers.
Reactions: wottle
Eric's Edge
98
Here’s an analogy. In classic film photography, when creating a print, there are different levels of skill involved. At one level, understanding the physical medium, the chemistry, and how light affects the silver halides in the paper. Is it helpful, yes. Is it absolutely necessary, no.
There is an art to making a print from a negative that spans a spectrum. It starts with a simple understanding of what exposure is needed to reveal whites as white and black as true black. There are “tools” and techniques that can help do this - Ansel Adams zone method for example. Follow the technique and you’ll get an acceptable print.
However, if you learn how to dodge and burn, you can pull details out in shadows or make the clouds distinct. If you look at some of Ansel Adams prints they change over the decades. Almost as if they were from different subjects. No two are the same.
What am I trying to say? Understanding what and how things work and why takes you to another level. Abstractions and higher level tools and techniques can keep you tied down to an amateur level. Understanding supports creativity. Sure, I can prompt my way to a solution. I can also pay someone to create something for me. If I do, I can take credit for facilitating its creation, but did I create it?
So, is a photographer using photoshop as a tool better or worse than someone creating prints using traditional techniques like hand dodging and burning? Neither. It’s not really part of the argument. I can be more productive and less wasteful in resources and time using Photoshop. The end result may even be better because the tool allows me to experiment more and more easily.
Am I a photographer if I don’t salt my own paper? Am I an artist if I create photographs instead of painting with oils? We’ve been here before.
Eric's Edge
98
The first time Og banged two rocks together and made an edge, they created something new. The rock, in and of itself, is a tool only after it was used by someone with a goal. It’s only potentially a tool until its tool-ness is realized by its use. Otherwise it’s just a rock.
An LLM is a tool. It might be a dirty tool - I don’t like the Fair Use provisions being used as they are.
And here we are.
Eric's Edge
98
As usual, the law fails to keep up with the tech. I personally feel the Copyright law Fair Use provisions were never intended to be used this way. It’s an abuse. However, as usual, corporations win out over individuals, and the law is applied unfairly. Ask yourself why Anthropic didn’t have to pay the penalties kids sharing music files did? They got a slap on the wrist in comparison.
Arbystpossum
100
68
USA
I understand the hate for AI, but this isn't a huge hobby, and the hardware is only getting older and more scarce. Better to make something while there's still machines to use it on.
Reactions: KennyPowers
611
Vibe coding & AI has opened the gate, allowing enthusiast laymen to participate in the learning and creation process of apps where before it was gate kept … not by people rather by life or bandwidth or learning style etc. For these folks, AI and LLMs are an amazing learning and productivity tool to flesh out their ideas, improve their pace & flex their creative minds in new ways that they couldn’t before and in ways to serve/contribute to their community.
Everything needs rules, guidelines etc. and there’s plenty of great discussion above about just that; how that can be implemented, but AI as a learning tool is and will be a game changer for many and that will undoubtedly benefit hobby groups like this one. I think the net gain will vastly outpace any potential negatives.
