Macintosh SE FDHD/SuperDrive Slow Booting with Checkerboard Pattern
Mark_W
29
27
Hello all, I picked up an SE SuperDrive last week and been busy restoring it. Cleaned the floppy drive and replaced the eject gear, recapped the analog/logic board and the power supply (it has an astec power supply and all capacitors tested good, but replaced them anyway), also dealt with melting rubber bumpers in the quantum hard drive (wrapped several layers of teflon tape around it as removing the bottom magnet requires taking out the head assembly).
Now after putting everything back together, it greets me with a checkerboard pattern:
Thought it might be a ram issue, i replaced all 4 ram sticks with known good ones (1Mx8, 8 chip, 80ns), but it still boots to checkerboard. However, after about 10 seconds it chimes and booted up as usual, and sees all 4MB ram. Power cycled it several times, it will always get stuck at the checkerboard screen for ~10s before chiming and booting up
Is this normal for an SE FDHD/SuperDrive? All SEs I have chime instantly when power is switched on. Reset is slow too, after pressing reset button it takes about 10s to chime. Otherwise this SE FDHD is fully functional.
SpocksBeer
Perhaps an analogue board issue delivering unstable power?
I have a similar issue with a Classic whereby if it's cold it'll take a little while before it chimes and boots. I'm putting that down to leaked electrolyte that's seeped into the AB near the optocoupler creating some undesirable, albeit temporary, circuits. After a few seconds things stabilise and it boots normally. I need to wash that board again.
Did you have leaking capacitors on the AB?
Reactions: Mark_W
SitesOnFire
15
I had similar issues on my own classic. Leaking capacitor fluid, I reflowed most of the analog board after replacing the caps too. The voltage it was delivering was not 5v. Sometimes if it's cold it'll still take a few seconds for the voltage to climb up enough so that it'll boot. I've never repaired an SE so I can't give specific advice.
Reactions: Mark_W
Mark_W
29
27
Hi all, thanks so much for your input. I double checked the voltage, reseated both rom chips as well as the swim chip, problem persisted. Swapped the motherboard into an SE chassis, same issue. Then I noticed something, I put a 47uf capacitor on C36 by mistake:
Which should have been a 1uf 50V cap. After replacing this cap with a 4.7uf one this mac chimes instantly on powering on.
Digging things a bit further, schematic shows this cap is connected to the sony sound chip directly:
So maybe replacing it with a larger capacitor, it will pull down pin 7 of the sound chip much longer till it charges up, and this somehow prevents the sound chip from releasing RST signal, which explains the checkerboard pattern
Anyway, problem solved and thanks again for your input!
SpocksBeer
Ah nice. Makes sense. The sound chip monitors voltages before releasing the reset line, and it would take longer to charge up that cap.
