Durosity
This is truly astonishing work! I'm looking forward to the Iici being added, Ive got a very problematic one of them. :)
Reactions: jack 68k
chuck.dubuque
27
Will Reconnaissance work with Macs with 3rd party ROMs? Or should I go back to stock ROM before using the tool?
joevt
324
127
Reconnaissance depends on the diagnostics mode in the ROM. The Mac has to work well enough to run that code. If the 3rd party ROM doesn't bypass the diagnostics, then it should work. But don't some of these ROMs skip the diagnostics (RAM tests, etc.) to boot faster?
rikerjoe
253
#MARCHintosh 2026 is here and I'm excited to share a project I've been working on.
You may know that many Classic Mac models have a diagnostics mode built into the ROM that you can access over a serial connection. But it's extremely cumbersome, limited, and there are a lot of sharp edges that make it difficult to do much practical with it.
Reconnaissance is a new diagnostics app that runs on your modern machine that makes it easy to run the ROM's built-in diagnostics as well as quite a few custom ones (some of which I have adapted from a certain diagnostic device that repair techs used to have access to...)
The first release supports the following models:
  • Macintosh SE/30
  • Macintosh IIsi
  • Macintosh Iicx
  • Macintosh II
  • Macintosh LC III
Support for more models (notably IIci) will be coming very soon, as well as a public release of full source code and SDK so others can develop custom diagnostic plugins in 68K assembly or C using modern development tools.
The app runs on macOS 14 Sonoma or later, Windows 10, and Windows 11. There's a lot of cool stuff to come and I can't wait to share the next update!
Check out this related thread about USB-serial adapters and cables
Happy #MARCHintosh, everyone!
Wow, this is so cool, Jack! I’m curious if you have received feedback on your tool working for units where the TechStep refuses to connect. I have two SE/30s that a recreated TechStep won’t connect to, but the TechStep works fine with other models in my collection. Great work!
AlexMac
109
59
Bavaria
This is really cool! I just tested it with my SE/30 and a Windows 11 machine on the other side. It connected reliably as soon as I swapped out the BMOW ROM Simm and used an original SE/30 ROM instead. On my Mac I could not use the serial to USB adapter, that's why I switched to Windows. Thank you so much for building this. I really appreciate :)
@RetroByte
Great tool!
Yesterday he immediately made it clear that the problems were related to the ROM on one of the three Macintosh II boards
One of the four ROMs turned out to be inoperable
I'm really looking forward to the further development of the project and the addition of new machines!
ajacocks
Maryland, USA
Such amazing work @jack 68k ! I love it when folks create solutions like this that make vintage computing more accessible to folks with the passion but maybe not the hardware talent.
- Alex
mattsoft
This app is AMAZING! Using it now with an SE/30 and it has helped me more in the past day than all the scoping and continuity testing for the 2 weeks prior. THANK YOU!!!
Reactions: @RetroByte
DevyDevly
25
20
New Zealand
Many thanks @jack 68k for creating such an accessible interface!
Reconnaissance helped me successfully diagnose an issue with an LC III I’ve been restoring.
1000 bonus life points to you and my gratitude 😃
