Expansion Memory Cards and Speed Limitations above 5MB on the Macintosh Portable
campbellashe
60
37
Asheville, NC
I'm currently in the process of developing RAM cards for my Portable. I have successfully created a 4MB and 8MB card and both work and boot.
However, I am trying to understand the issues with slow access speeds when more than 5MB are in play (1MB on the board, 4 MB on the card). Initially I thought the slow down was only post sleep. But now I realize that the slow down occurs regardless of cold boot or sleep. I haven't done in depth testing but using SNOOPER Memory Test, 85% speed with 4MB but at 8MB drops to 22% consistently.
Are there any solutions to this? Is this the GLU/DTACK issue only occurring above 5 MB total?
I was confused somewhat related to the prior discussions on this issue; I thought the impact of slow speeds was only after wake from sleep.
Thanks for any direction.
[ my board designs are available on GitHub if desired
8MB https://github.com/2tf2294x4g-maker/MacintoshPortable8MB_RAM
4MB https://github.com/2tf2294x4g-maker/MacintoshPortable4MB_RAM]
Reactions: David Cook
campbellashe
60
37
Asheville, NC
8MB RAM Card — Speed Testing Results and Analysis
Following up on my earlier question about the slowdown with more than 5MB of RAM, I've done some deeper testing with my v2 8MB card (9MB total system RAM) and wanted to share the findings.
Benchmark results (Snooper Memory Move)
  • 4MB card (5MB total): 85%
  • 8MB card (9MB total): 51% -- cold boot, restart
Testing $FC0200
Based on prior discussion in this thread, I tested whether reading $FC0200 via Macsbug (DM FC0200 → G) restored speed. It made no difference — still 51%. This confirms what David Cook found with his Quiet Portable INIT: $FC0200 does not fix the slowdown with an 8MB card.
DTACKSpeedTest results (this is a small app that I created)
I ran a custom read-timing tool that tests each 1MB boundary across the expansion range against a built-in RAM baseline:
AddressTicksRatio
$100000–$4000001042–1043~1.00x
$500000–$8FC0001077~1.03x
Read timing is stable throughout the card — only 3% slower in the upper 4MB, essentially unchanged from the lower region and from onboard RAM. This is nowhere near enough to explain the drop in Snooper. But is slow throughout the range.
Conclusion: read timing is unchanged throughout the memory range .. but slow; is there a write difference?
Open questions
  • Does the GLU use different DTACK timing for write cycles vs read cycles to expansion RAM?
  • Are there other GLU registers beyond $FC0200 that control write timing?
Happy to share my rudimentary DTACKSpeedTest tool if anyone wants to run it on other cards/configurations.
campbellashe
60
37
Asheville, NC
I did confirm that a poke of $FC0200 after sleep does improve speed from 22% to 51% on Snooper speed test consistently. Before sleep 51%, after sleep 22% and then post poke -- back to 51%.
Addendum:
I’m using a non back lit Portable.
David Cook
277
339
Let me try to summarize your findings:
1. The slowdown occurs even on a non-backlit Portable. (Previously, I thought this was a backlit problem.)
2. Speeds are:
A. 100% with no memory card (1 MB onboard)
B. 85% with +4MB memory card
C. 51% with +8MB memory card
D. 22% with +8MB memory card after waking from sleep
E. 51% with +8MB memory card after waking from sleep and then poking $FC0200
3. Slower speed occurs for reads at any memory location. That is, if the Portable is at 51% speed, this is true for reading onboard memory as well as the last 8MB of added memory.
campbellashe
60
37
Asheville, NC
This is the baseline Memory Benchmark on the non back lite running Snooper 2 and OS 7.1. Bluescsi as drive.
mmu_man
201
144
Having more chips on the card increases the current pulled on the bus and likely the access latency, but likely not by that amount, and unless the chipset compensates for this programmatically it shouldn't see anything actually… IIRC these are synchronous, so it's not like they reply when the data is valid on the bus and it takes more time…
David Cook
277
339
According to Apple's technical note:
"Unlike the original Macintosh Portable which required one wait state, the backlit Macintosh Portable requires zero wait states when its processor is accessing memory locations in the expansion RAM."
"It is possible to expand RAM up to 8 MB, however the zero wait state /DTACK signal and the /REFRESH signal are generated only for the first 5 MB of RAM address space. Apple does not recommend that you use the processor-direct slot for RAM expansion, but if you are planning to design a processor-direct slot (PDS) expansion card for additional RAM, keep in mind that timing, particularly the /DTACK signal, is critical."
Because Apple originally intended RAM above 5 MB (1 MB internal + 4 MB RAM board) to be the SLIM cards, could it be that Apple increases the wait state for ALL memory accesses when it detects more than 5 MB of RAM? That is, you must use the /DTACK signal (via the PDS slot or a clip on wire) for your 8MB card to run at full speed?
Reza Fouladian's github page pretty much confirms your 51% speed number. "With access to the DTACK signal, RAM access speeds are greatly increased compared to regular 8MB RAM cards, especially when going over the 5MB mark."
If we
campbellashe
60
37
Asheville, NC
Agree. I got in contact with Reza and he confirmed the use of the PDS and DTACK, I’ll try to place a wire to the DTACK pin on the PDS from my CPLD and rewrite logic. Give me a bit to wire something up and i will let you know.
Reza:
“For my PDS RAM card designs, they assert /DTACK on their own so there's no waiting for the CPU GLU to assert it.
For the ones that use the RAM slot that do not have access to /DTACK, I typically use a card in the ROM slot or PDS slot that handles /DTACK assertion, just based on simple decode logic so it doesn't take much.”
mmu_man
201
144
Well yeah then it's logical than the larger RAM, the slower it gets on average, if more of it is in the one waitstate section. It doesn't explain the slowdown for only 4MB though…
Froggy814
166
46
Squaw Valley, CA
So if it gets slower because of no /Dtack signal, couldn't you program a chip and put it on your PCB so that it asserts /Dtack?
EDIT:
I will try to get some speed tests from my PDS 4mb card... My Portable's torn apart right now!
campbellashe
60
37
Asheville, NC
Okay. Wow. What a difference the bodge wire and code logic change made with driving DTACK Now no slowdown at all on the 8MB card....
The numbers are better than ever....
The fix: the ATF1502ASL CPLD on the RAM card now asserts /DTACK itself, via a bodge wire from CPLD pin 42 to PDS slot pin B7. The CPLD monitors the address bus and data strobes, and whenever a cycle falls within the card's memory window (0x100000–0x8FFFFF) it pulls /DTACK low directly — bypassing the GLU completely. The output is tristated for all other bus cycles so there's no contention.
Yes. It does need a bodge wire that plugs in to the PDS...
Froggy814
166
46
Squaw Valley, CA
Wow! 102% better! That's an improvement!
Wondering about how Sideburn put (I think 13mb) of ram in his Portable, and was wondering, how big is the ram space in the Portable really and can you use more of the empty space in the block diagram to max out the Portable. It was just a thought to throw out there.
SuperSVGA
80
51
And if you're curious of the stock numbers from the CPU GLU:
0x000000 - 0x4FFFFF: 2 clocks
0x500000 - 0x8FFFFF: 6 clocks
0x500000 - 0x8FFFFF (registers misconfigured or untouched): 18 clocks
David Cook
277
339
That's what we suspected. So, if you average the clocks (2 + 6 / 2 = 4) over the entire memory range, you end up with the 50% slowdown (4 instead of 2).
Reactions: Froggy814
daanvdl
Netherlands
Very impressive solution! Having the CPLD assert /DTACK directly is both elegant and highly effective, eliminating the slowdown entirely without requiring an INIT. Excellent work!
David Cook
277
339
@campbellashe Do you have a M5126 backlit Portable? I think you'll want to add a 7MB jumper option, as that model has an address conflict that prevents 1 MB + 8 MB.
