I finished my office refresh
683
I finally finished my downstairs office refresh. I painted, tore out the old 70s carpet LOL installed a laminate floor and installed a gang box for and hung my tv on the wall.
Now I have to reinstall my shelving and put everything back in there which is not easy because I have a lot of junk LOL. But I am both relieved that it is done and happy with how it turned out.
Next on the honey list; do the same thing to the guest bedroom across the hall. Oh well, at least I have enough paint and three cases of laminate pergo flooring to get started with. :D
I may install a ceiling fan in that room at some point. It would be pretty easy running 110 from the tv gang box to a cfr box. I’d only have to go through one joist I think. Oh well, a project for another day :)
Reactions: eric and Froggy814
683
LOL it was the one thing I opted to keep attached to the wall and paint around lol but yeah, there’s my entire childhood NES, SNES, Genesis, Atari2600, Wii, n64 and some c64 carts in there as well as random winbox, apple software.
If anyone took it off, there would be a big square of the old dingy color lol. No worries though as I still have 3gallons of a 5gal bucket of candlelight beige left that I used+ the paint code so anyone can make it should a future purchaser need it (I have made a bible of sorts of all the weird idiosyncrasies that this old house has + color choices/codes etc. the electric panel box that was NOT labeled grrr 😖 . What a pain remapping what all those dang switches did 😆 - that was a sucky job especially in an old split level with three sets of stairs - just woof. Anyways, future owner will benefit from this bible ( who’s kidding - me & my musho brain too lol).
That TV is 66 pounds which is so heavy! I had to buy an extra heavy duty two stud tv mount because I need all that I/o in the back to connect all my retro gaming boxes. The i/o is pretty awesome with stuff modern flatscreens just don’t have. This old thick boy Phillips has rca/composite/coax/usb/hdmi/s-video/digital audio, etc. and lots of it both rear facing and side facing. I’d have replaced it years ago if it weren’t for the wonderful and convenient I/o situation it has going on. I bought it in 2009 and have been lugging it around since. I don’t think they make them like that anymore sadly. As an example, my big fancy schmancy Samsung 65" smart tv I bought a few years back already has an entire line of failed pixels top to bottom. Juxtapose that to this old Phillips that is just a tank and has all kinds of awesome i/o and has lasted two moves in 17 years.
Reactions: Froggy814
683
Got my music gear/amps etc back in and some more of the bones in place. Changed it up a bit and I’m happy with the new placement of my stereos and a few of my amplifier&cabinets.
This is the fun part I guess lol. It’s curriculum night for my kiddos so I have to stop for now and will pick up this evening. Oh yeah, can’t forget the Super Mega Ultra Fudgy brownies I have in the oven. Wife requested them yesterday so can’t forget about those lol.
683
Looks like you went with Pergo for the flooring, how's the quality? I'm looking into options for laminate and haven't seen that name in a long time.
I’ve really liked it for a number of reasons. The quality of the material has been fantastic - Of all the floating floors I’ve done, this pressed composite material has been the sturdiest. It also cut very cleanly with zero chipping on my circular table saw with appropriate toothed blade. It has the pad material built into it which is really handy. Having to lay pad and then try and build a floor over that flopping around is an huge PITA. All you have to be aware of is potentially adding a vapor barrier if you are below grade for radon gas -or mold/moisture. The joints come together quite cleanly - this part takes the most getting used to but when it comes together, it snaps together very tightly. I definitely recommend buying a high quality pull bar. My pull bar Ive had for about 15 years now started to bend under the stress of my hammer. It did the job but a nicer maybe a bit longer (2ft long) would have made things a bit easier. Lastly the look is excellent - I love the wider board and the coloration+texture makes this look like actual wood floor. It’s an impressive manufactured flooring material system.
Pergo is on the higher side per sqft in my neck of the woods but this one was on sale for only a $1.99sqft at my Lowe’s which I thought was a bargain price so bought in. I initially picked up 10 boxes for a little over $500 bucks but I have 3.5 boxes left to start on my guest bedroom after I get all my junk back into my office, so between some fresh paint and this new floor, per room I think I’m probably in about $275-300 bucks not including my own labor of course. After using this stuff, I am a fan of Pergo flooring. That is for sure.
