C support libraries
goon
16
Hi,
just wanted to say I started making additions to the C library, it was made on a Powerbook G4 running Debian Linux.
Here's the source code of the first library :
goon
16
libactorc1 is now at version 0.1.6. It should be usable and only has one malloc system call (stdlib.h/malloc.h). Source code is here : http://sf.net/p/libactorc
I will start compiling both libraries later on.
There might come a recent MacOS version of both.
goon
16
libportc1 is now at version 0.1.28.
It does not use any C/UNIX-like functionality so it should be very portable.
The macOS version is therein.
It remains untested.
nilobject
31
22
that's great youre using the g4
have you run your code through an llm?
there's a few obvious crashes in there that a chatbot will pick up for you
goon
16
Yes, there's indeed a paid for version on the latest linux tarball.
It has a HashMap en surplus on the common tarball and is WIP.
It uses a list of values and offsets, where the offsets represent a list value addition towards the following value. A (hashmap)value has a target on the hash map, meaning a return value on the ref of the hashmap. So you backtrack enough (hashmap)offset structures to find the value on length - sum of offsets with values in between then returning the correct value if it exists (else you return 0/NULL or something).
The key indexes are a id/voidp (void*) which target 0x0000 to 0xffff on a 32 bit machine. The offsets are therein, the keys are in this range.
So you could make a binary string containing every index in that range but mine has hashmapoffset structures to diminish the length of the binary string for example.
I am always glad to use my G4 for it.
nilobject
31
22
yeah cool. i love hearing about custom data structs
my nilobjects are key/value maps where every node is a parent
sure makes coding easier to have a standard
