Macintosh Iici build questions/MMU
T-Man
42
Tennessee USA
I have a battery bombed Iici with several legs of the MMU (and multiple traces) eaten away. Aside for the MMU, the other chips look salvageable. I have a Bolle Iici new board and some parts for it and had planned to use a IIsi board to salvage chips /IC's as a backup. However, now looking closer and before starting a lot of work, I'm not so sure about the MMU. The text on the MMU from battery bombed CI is barely visible but is consistent with this picture of a CI MMU I enlarged from "Recap-A-Mac". The IIsi MMU is a picture of the board I actually have. Can I use the MMU from the IIsi board to replace the damaged one on the Iici board?
T-Man
42
Tennessee USA
So it’s looking like the MMU on IIsi and IIci are the same chip. The build will be a while but will give it a shot. Thank you for posting. Will go look again, on looking at the traces leaving the chip, there seems to be diffeneces.
Reactions: DevyDevly
DevyDevly
30
22
New Zealand
I was re-reading this and might have made a mistake - apologies.
The MDU (UK11) on my IIci machines is either a 343S1059-A, 343S1059-B, or 343S1018-A.
It was the RBV (UE9) that is the 343S1019-A.
i.e. I don't think you replace a IIci MDU (UK11) chip with a 343S1019.
T-Man
42
Tennessee USA
Bummer….not finding the part number on another board to replace UK11 MDU on the IIci board…. maybe file some edges and microsurgery someday
T-Man
42
Tennessee USA
Relooking at the boards I have (one battery bombed IIci and three battery bombed IIsi) and online pictures now pretty sure I have a number to add for MDU identified both on IIci and IIsi logic boards. That is 344S1018-03 which is both on the Recap-a-mac picture of IIci logic board and a IIsi board that I have.
Is this part number the only number on the chip that matters, ie marks them as the same? All of the other numbers match EXCEPT the top row.
The only part number that matters is the apple one - 344S1018 - the others are the internal designation for the part, as they were made by Philips, VLSI - whoever had capacity, there were multiple sources.
