I Need Help-A Problem With Installing Linux Mint On a 2012 MacBook Air
2112st
316
123
Northeastern New Jersey, USA
Hey folks...it looks like there is a problem with installing Linux Mint on a 2012 MacBook Air I want to buy...
You need to have an Ethernet connection to get the proper packets to get onto the internet via wi-fi. For me, that's impossible, because my internet connection is through my apartment building's wi-fi. That's how I connect to the internet. I'm watching this video now, where this gentleman talks about that.
What can I do to get around this problem?
615
You can create a wired connection for local devices by using a router in bridge mode. Basically the router connects to your building's wifi, and provides 1-4 wired connections for your local devices. You can get routers at the local thrift stores for cheap. If the particular model you have does not support bridge mode natively, you could also possibly flash them with DD-WRT, OpenWrt, etc.
This works great for devices that don't have built-in wifi hardware, or devices that prefer a wired connection. I use a router in this mode for my workshop in my garage to connect my CNC machine to the internet (PC without wifi). I also use it in my home office where there is no physical wired connections available for older desktop macs without wifi hardware.
Reactions: 2112st
703
If you have another Mac, you could use internet sharing and connect a thunderbolt cable between the two or if it’s older, a cat cable to a thunderbolt to Ethernet adapter plugged into the 2012mb - something like that
It’s very likely that Mint doesn’t have the Broadcom WiFi drivers in its installer hence why it’s asking for Ethernet. I’ve run into this on most distros whose foundation is Ubuntu. If you are not set on Mint (which is a fine and very popular distro), you could try one that likely does have your BC WiFi driver in its installer out of the box like MX Linux. MX is known for broad support of early Intel Macs.
Anyhow, good luck
Reactions: 2112st
S. Pupp
98
53
The Apple Airport Express can be used in bridge mode, and is cheap (I bought a pack of five for about $50) at shopgoodwill.com. It can be used to transmit music and as a print server.
Setup is complicated by Apple's abandonment of the Airport line of products. Apple Airport Utility works on a PC and MacOS prior to 27, but Apple's website suggests it is not available for iPhone or for MacOS 27, unless you'd installed it previously.
The Vonets devices and routers mentioned above are set up in bridge mode simply through a web browser, and work well. The Airport Express is probably best reserved for if you'd benefit from its other features.
Reactions: 2112st
2112st
316
123
Anyhow, good luck
Hey there!
So, a question-I'm a total Linux newbie. Is MX Linux good for someone like me? That's why I wanted to try Linux Mint. But I just want to use my building's wi-fi to download and install-and if MX Linux can do it, then I'm going for that instead.
703
Hey there!
I think if you were to tier distros from ease of use, most would rate MX as a mid tier
distro but I have to tell you, I think you would do fine with MX+XFCE out of the box. I think as you’re new to Linux, it’s more important for you to have a good first install experience. It really is a PITA for folks to install and then stuff doesn’t works because your WiFi or sound or touchpad driver wasn’t downloaded because you didn’t have Ethernet. Get a good experience under your belt first and then get comfy with how Linux distros generally get things done. I think that is the best way vs suffering through the sadistic fires of Mordor just to get a functional system/desktop. Here’s a video of an 08 MacBook getting MX installed on it.
Good luck.
Reactions: 2112st
2112st
316
123
Good luck.
I may order the MacBook Air Friday. Will keep you posted.
2112st
316
123
MacBook Air ordered. I should get it 11/5. I'm driving to northern New Jersey tomorrow; I'll stop by MicroCenter to pick up a flash drive.
nilobject
115
45
i just installed debian to an imac2012. during the installation it asked for an external drive to be plugged in with the broadcom firmware on it. was very easy, it searched the drive for the firmware and installed auto. then it asks you which desktop environment you'd like to install. sounds counter-intuitive, but base debian is the beginners friend.
Reactions: S. Pupp and 2112st
RetroViator
169
retroviator.com
I have Debian running on my MBP 2012. It works well, but it’s annoying that I must uninstall and then reinstall the WiFi drivers with each Linux kernel upgrade.
The solution is spelled out pretty well at https://wiki.debian.org/InstallingDebianOn/Apple/MacBookPro/9-2.
Firmware-b43-installer will only provide 2.4GHz WiFi, but the broadcom-sta-dkms with the installation of Linux headers solves the problem. The trick is the Linux headers need to be installed first, then broadcom-sta-dkms.
[sudo apt install linux-headers-$(uname -r) && sudo apt install broadcom-sta-dkms]
If the broadcom driver is already installed, remove it first, then install the Linux headers. Then reinstall broadcom-sta-dkms. Reboot between each step.
2112st
316
123
Good news and bad news...
Firstly, the 2012 MacBook Air is working well, EXCEPT-
Neither of the USB ports seem to be working. I wasn't able to flash MX Linux onto the Air.
What DOES work is the SD card slot. There's a thunderbolt port as well. I guess I'm going to have to get an SD card and flash it.
Very frustrating.
:mad::cautious:
Edited to add: this Air is running Catalina 10.15.7.
703
Very frustrating.
:mad::cautious:
The usb don’t work at all in Catalina? As in if you plug a usb mouse or kb or flash drive - they all don’t work?
Have you reset SMC? PRAM?
Reactions: 2112st
2112st
316
123
I don't play games; I will use this for writing fiction, web surfing and email. What would be good for security, insofar as accessing things like Gmail through this Mac? Again, I'm a TOTAL newbie. :)
703
I use thunderbird client which is connected to my gmail accounts. To download it, search for "MX Package Installer" and open it. In the upper hand corner, there is a search window - type Thunderbird there and it should pop up as an option to install. It should look like this.
Being that you are a Mac user, you might want a dock too for some familiarity (I sure do). I use "Plank" as its super low-resource which my c2d mac appreciates lol. To install it, the process is the same - just type in plank in the upper right search bar of the MXPI window and you should see it pop up. For writing stuff, I use the word processor it comes with which is Libre Office.
Speaking of DLs, I realized I havent updated this particular macbook in a few days (this one is part of my upstairs den stereo where I stream stuff via Pithos (another neat app if you like Pandora). Anyways, hope you enjoy.
Oh yeah, do the usb-a ports work in MX?
