Patching up a PowerTower 225
phipli
259
I picked up a "non-working" PowerComputing PowerTower Pro 225 recently. Find here a record of my progress so far getting it up and running.
Yes, I'm linking off site, but... I'm not going to not put things on my own site and it would be silly to write the whole thing out twice. Plus I have forum data loss trust issues. 🤣
Useful info in the post so far includes information that might help you find a replacement power supply for your PowerTower Pro. It isn't as easy as it used to be because all the modern PSUs have weak 5v rails and a 120mm fan only millimetres from the flat surface of the top of the case. Or the power socket or a switch where they clash with the rear opening.
Reactions: eric and Nitram78
phipli
259
I have just finished updating the linked post (the same link above still applies).
The power supply I ordered arrived on Friday so I've progressed the build to the point that I now have what I consider a usable system. Basic stats are...
  • 300MHz Sonnet G3
  • ixMicro ix3D UltimateRez Video Card
  • 16GB SATA DOM
  • Bootable IDE Optical Drive
  • 350 Watt FSP Power Supply with 32A 5v Rail
Reactions: croissantking
PPC_505
22
Fantastic writeup. I'm not on here too often so I just saw this, but you've made me realize I need to check the specs on the replacement PSU I used on mine. I didn't even consider any of the amperages, just picked up one that fit from thrift.
Reactions: phipli
