Mac Portable meets Dynamac: ELantern, adding an EL panel to a Portable
techknight
144
139
North Carolina
This is still VERY much a work in progress but, I figured I would do something fun.
I work on macintosh portable machines all the time, and as such, I have parts lying around in various nooks and crannies of this house lol. The other thing is, the macintosh portable is known to have bad LCDs now with excess ion buildup causing tunnel vision, image retention issues, and of course vinegar.
Outside of that, A dynamac (and an outbound) have been on my list for awhile but the likelihood of ever owning one, especially at a reasonable price is next to nill.
So. I'm going to make one out of scrap macintosh portable parts:
techknight
144
139
North Carolina
Here is a test setup. Using Androda's Portable to VGA adapter as my testbed along with a secondary device to drive the TFEL panel:
techknight
144
139
North Carolina
Isn't that just gorgeous? My test environment was a success, and I even like the inverted mode, it actually looks decent. Does it save on power? Nah not really. EL panels tend to increase current due to the amount of pixel transitions happening per row because of the capacitance of the panel itself.
Reactions: Kai Robinson
techknight
144
139
North Carolina
Taxes! That's a lot of taxes! This is awesome! I will definetly be following this!
Oh but it gets worse... My mouser cart:
I am never going to financially recover from this (In fact, i dont have the burnable cash at the moment, so ill have to put this off for now)
campbellashe
62
40
Asheville, NC
@Froggy814 and @techknight
Just jumping on this post for a general question....
Any luck with drop in replacements that would replace the LCD outright in the Portable with an equivalent -- the vinegar syndrome is a real problem and I have two non backlit machines impacted by it.
Therefore, I'm still looking for a drop in replacement for the LCD panel on the Portable. I've created a replacement that needs external battery and uses the REZA board for translation to HDMI. It is great but modern LCDs are power hungry; and it needs a separate battery to run it. I also don't know how to budget the watts to allow a modern equivalent that uses the original connector to power everything.....
Froggy I know you were working on a board of your own.
I guess I'm looking for the various parts to pull this off:
a) a board to take the OG signals from the logic board -- REZA's board -- got this part and perhaps there are others...I think this is what your board does ?
b) an LCD/ board that displays the 1 bit 640x400 image under available watt budget (I have not actually measured the limit, most modern ones I can only get to about 2.16 W budget as they all have backlights)
Part A is around in Reza's board and I think Froggy is working on a similar solution that is more slick, and is this yours as well
Part B is the hard part -- sourcing and LCD with low wattage -- don't know if e-ink or other solutions exist at the 10.1 inch size that would work... let alone modern equivalents that accept the 640x400.
Thanks for any direction....
Reactions: techknight
techknight
144
139
North Carolina
Not quite the right thread for this, since this is about the EL project but.
It's not super difficult to pull it off, you need proper DC-DC converters that feed from the battery power, and yes, the power budget isnt there. Not even for this EL panel, but a lithium battery will hold the whole setup for a good long while, and whilte turned off, the original charger will charge it.
I used the REZA repository to base this design off of.
But LED backlights usually arent that expensive on power, it shouuuuld be alright.
eink would be IDEAL for this. But we are just now starting to see high framerate ink disaplys, and theyre still prohibitively expensive. In time, it may just be doable. it would also look close to original.
techknight
144
139
North Carolina
Sorry. Saw a “new” screen on a Portable and got excited….
Well, at least the REZA repository in that case has everything you need to throw a screen in it. Kuldgy? yes. But it does work. Only option outside of that is to go full fledge FPGA and drive a panel directly. Then you still have to deal with backlight control and power.
I really want to investigate e-ink when the high speed high framerate displays get cheaper.
494
Now that you've mentioned FPGA . . . wottle has image position figured out.
How much trouble will it cause to use an inexpensive project board to throw your 640x400 Page buffer onto a larger panel inside the Luggable bezel constraints for a perfect fit?
edit: way cool project!
techknight
144
139
North Carolina
The REZA respository already takes that into account by changing the output resolution and scaling the input resolution to fit. You just get aspect ratio distortion when doing that, as now you have to rely on the built-in scalar of the RTD2662 chip.
Anywho for my project, the panel is 640x400 native so I can avoid doing any of that.
Also with my project, I had to genlock the input and output. I noticed if you do not do this, you get a beat frequency between the two refresh periods with either dropped or duplicated or torn frames causing a jerky mouse or motion.
494
Cool, native res panel is great. Was thinking if the likes of ASUS Eee PC 10.1" panel scaled & pictureframed. A larger, higher resolution display that might fit with a 1:1 framed portion would be better. Loving your project.
There's nothing wrong with a Luggable display that a printed, divot free front bezel and a NumPad won't fix. ;)
751
Yeah, scaling a lower resolution onto newer panels is a challenge. I got a passable image for the Lisa's standard resolution upscaled to 1024x767, but it wasn't a clean multiplier, so it is not as sharp as you'd like. You really see it on the standard "gray" checkerboard pattern for the desktop on these monochrome displays. I wouldn't recommend for the best image quality. You're better off if you can get a widescreen display that is a multiple of the height and simply shifting the 4:3 image to fit the opening. Short of the native 640x480 panel you are using, a 1280x800 would likely be the best for this. although I really love the look of that EL panel.
techknight
144
139
North Carolina
Well the panel I am using is native 640x400 so it fits perfectly.
640x480 would require letterboxing. 1280x800 would also work, but thats not something an EL panel came in. More common resolutions today would be a 1920x1200 which is high bandwidth and would need careful PCB routing and a good FPGA to drive.
I really wanted to use the Sharp version because theyre far more plentiful for much cheaper, but it wont fit in the upper housing. So I had to settle on a Planar.
