400K Floppy Drive Issues
Duke09
Having some issues trying to get the full mechanism working on both the -02 and -22 variants. Cleaned out the old grease best I can and added some new grease, but it is always stuck in the down position/loaded. It seems like there’s a bar near the near that makes it go from the up to down position but refuses to budge at all. Anyway managed to fix one of these drives successfully?
Paolo B
254
141
Nagoya, Japan
Love those old drives, they are so musical. I suggest to tear down the mechanics and to clean it thoroughly. I remember one drive with a completely “glued” mechanism.
Daniel Hansen
173
128
You need to take the cage off and really let it soak in something that will break down the grease-turned-glue... there are a few spots that are really, really difficult to access directly, so soaking time is the key.
Actually, Epictronics recently refurbed one of these, using WD-40 to break down the old grease:
ScutBoy
314
Northfield, MN USA
I found that a drop of xylene (a solvent you can get at a hardware store in the US) does a good job of dissolving the dried up grease on these drives. Just a drop or so from a cotton swab should do the trick.
Do this in a well ventilated area!
I found that isopropyl alcohol doesn't do a good job, even with a good soak. Others might have a favorite solution (pardon the pun) as well.
