Airport Card Question.
I found a card at work in the original box, in great condition. I've got it installed in my G4 Cube for now so as to test it. Card is recognized. System Profiler shows Firmware 9.52. OS is 10.4.11.
PROBLEM: "Wireless network not available."
Card is "turned on" as per the wifi menu in the menubar. System Preferences > Network > Airport shows the Airport ID. I manually added my networks, including a Guest network with security totally disabled (for this test). Still will not show any networks at all.
Router is an Apple Airport Extreme "white tower" from 2013 which works perfectly with our modern Macs and iPhones. I can edit settings of that router with modern Macs, but not my Cube because the Airport Utility on the Cube is too old to communicate with it. Even so, like I said, I've enabled Guest with Guest Network Security set to "none" but still my G4 Cube / Airport card will not show even a single network.
Yes, the antenna cable is attached to the card and the card is properly socketed (as per the fact the card is detected by Mac OS Tiger on the Cube).
ANY THOUGHTS?
UPDATE!
@Kay K.M.Mods very kindly informed me that only the silver colored dome shaped Apple router will be compatible (the one at left in the photo below). Thankfully, a co-worker has that very silver router at his home and will bring it tomorrow so I can test if it works. The only issue is whether he still has the original AC Adapter — Ack!
ANY THOUGHTS?
UPDATE!
