I'm troubleshooting this Apple IIc which shows horizontal lines on boot with no sound:
It got into this state because a capacitor on the floppy drive went bad and shorted the +12v to Ground. By the time I found the culprit, the +12v did some damage on the main board, and need help troubleshooting what's damaged.
First thing I checked was the RAM. It seems that 4 of the ram chips bad. Probing D(in) pin 2, 4 of the 16 ram chips seem to be pulled low. Thermal check shows that the four RAM chip are running at a higher temperature than the others, so I've ordered replacements for these.
However, I don't think that's the only issue here. I get the same video output with and without the CPU/ROM. Looking at thermal, the CPU and ROM give off no heat. I've tested the ROM separately and confirmed it works. My guess is that the CPU drives reading of the ROM so since CPU has no activity, neither with the ROM. I checked and CPU gets 5V in. The lines BE (Bus Enable), RDY (Ready), and RESB (Reset) are all high as expected. My guess is either the CPU is bad or maybe oscillator is bad. I tried to check the clock input at PHI2 and not sure if it looks good, I thought voltage would be higher (image below). I don't have a good reference to see what I should expect, my oscilloscope is very cheap so I don't fully trust it. (DS0138mini). I’ve ordered one of these CPUs in case it is bad.
The power supply +12, -12, and +5 look good, so no worries there.
I’ll keep the thread updated on the progress, as it will take a while for chips to arrive. If anyone has any other suggestions please let me know.
