I just picked up an Apple III locally and it came with a ProFile 5MB Drive (unfortunately no Profile card in the machine), two Apple /// Monitors, and the external floppy drive. I need to replace the RIFA caps as the big ones are cracked significantly.
However, I decided to start it up in the garage to get an idea of if it could boot. I know nothing about the III, other than that they were short lived and had thermal issues. When I started it up, the good news is I do get a picture out and the display on the /// Monitor looks pretty good. (The other /// Monitor has a tear in the anti-glare screen, so I need to disassemble it and remove. the screen). Unfortunately, the screen displays two screens of gibberish.
First, this, with a square in the bottom right that is changing:
Then I get a second screen that looks like this:
The screen goes black and then it repeats. I didn't let it go too long, because the RIFA caps looked like this (Yes, it appears there is a hole in one of them):
The remind me of the Apple II when it has memory chip issues. So, I decided to remove the RAM card, give everything a nice wipe down, remove every RAM chip, spray some DeOxit on the sockets, and reinsert them in a different order. I also removed and put DeOxit on the CPU socket. Unfortunately, the same result.
While I wait for my caps for the PSU, any thoughts on where I can start troubleshooting / ordering some replacement chips. Is it possible the CPU is bad? Is the 6502 available to buy if it was?
