I have a few of these drives, and wanted to see how different they were from the more commonly found "caddy" drives inside the AppleCD SC Plus, CD150, and so on. This example I show below is not currently working. My thought was to repair it in the same way I've done in the past - replace the leaking SMD capacitors on the logic board. Oh my is this a different beast. I've never seen anything online regarding this model of drive, so I am hoping to change that. Warning - lots of photos below!
Here's the top side of the drive mechanism.
Front view.
Side view. 1988 - wow this is an early CD Drive!
Rear view. So many interconnect cables.
This is what the drive looks like separated from the bottom portion. I believe this board handles SCSI data and audio. More interconnect cables...
This is what it looks like with the top logic board removed. This was a pain. Those yellow wire bundles are connected tight on each end. Still no sign of any leaky SMD caps.
Eject system. The yellow colored gear looks familiar. Hope it's not as brittle as those found on the auto-inject floppy drives.
Close up of the drive controller PCB.
Underside with the plate removed, exposing the laser.
One more view inside, a little closer.
Front view.
