Hello! I recently bought a Mac SE (1MB with 20MB HD), which is my first compact Mac since my beloved Mac Plus back in 1989.
Unfortunately, after one night setting up some BlueSCSI drives, I've accidentally turned it into a dedicated Dark Castle machine.
Setting up the SD card with multiple HD images worked fine, but it refused to run games that usually started from a floppy, like Dark Castle & Beyond Dark Castle. The error message suggested that there wasn't enough memory for the game and the Finder, and the easiest solution was to boot from the floppy drive. Instead of making a new floppy, I tried to use the System Switcher app to boot into the Dark Castle folder on one of my disk images. That worked fine, but now the computer always boots into Dark Castle if I have the BlueSCSI device installed.
I've tried several recommended key combinations I've seen mentioned online to choose a different boot device on startup, but none seem to work.
Is there a solution besides erasing my SD card and starting over with new images?
Also: What is the correct way to do what I was trying to do, temporarily booting into a floppy image? Is it possible without physical floppies, or one of the floppy emulator devices I've seen?
Thanks in advance for any info to what is no doubt a newbie question. My old Mac didn't even have a hard drive!
Chuck
Chuck
