BlueSCSI v1.1 issues
TheCaddyMan99
24
New Jersey
I don't quite know how to add things to an image using emulators yet. I'm still working on that one
One thing I have noticed today since I decided to tinker with the Mac today, I put a blank image on the blueSCSI, and booted from a System 6 startup diskette that I use with my dual FDD SE. And I noticed that none of the images that I put on the BlueSCSI show up on the desktop.
I'm sure this is indicative of a larger issue with my device and I will probably have to identify and fix this issue first, since I was able to at least see blank images on my external BlueSCSI.
TheCaddyMan99
24
New Jersey
just to get it out of the way, i downloaded the example files and boot them on my SD card, only for the same result, I really don't know where i'm going wrong, my bluescsi is recognizing SD cards, reading the files on them, but it's not emulating the drives, is there anything i'm missing, is there a firmware version i'm missing? something anything to get this to work
This Does Not Compute
347
505
Did you buy the BlueSCSI as a kit, or preassembled? Are the terminating resistor packs installed? (Take a photo of the BlueSCSI and upload it here if you're not sure what those are, or if they're installed correctly.)
