[C programming] Gracefully force 1-bit graphics in a wide ranging selection of 68k macs
Mu0n
701
675
Quebec
Crossposting from another thread, this is a list of my ongoing goals:
Black and white compact macs targetting mostly 512x342 in 1-bit color depth field
BUT
-must not crash if a more recent machine is used
-System 7.5.5 is the most recent that I target
-When possible and not too feature rich, System 1.1 on a 400k MFS disk should run my stuff
-must gracefully center the image if a higher res is used
-must deal with color depth field if it's detected but still use 1-bit gfx data
-must deal with gracefully using graceful detection routines
-great if a Mac128 runs it, but not a big deal if not.
-great if a Mac512 runs it, it should in theory but I don't own one.
-Mac Plus is the natural main target that I can easily test out on real metal
Here's what my current checklist algorithm does. Suggestions and warnings about omissions are very welcome:
Step 1:
Declare a SysEnvRec (system environment record)
Fetch information using SysEnvirons( )
If the mac environment (machine and system/finder) is too old, it should return an error code but that's probably good, since you can expect 1-bit depth in this case. No need to deal with color depth modes!
If the mac environment is too new, then the record returned will be too big, and I still have to figure that out. Maybe a non-issue if I cap things to Sys 7.5.5.
If it's just right, then I can safely declare that if the record's systemVersion is less than 6.0.4 ( less than 0x0604) and/or the machineType record is less than 0, then 1-bit depth is guaranteed (right?)
Step 2:
If 6.0.4+ is here or if the machine isn't old, then the next step that should work is to use Gestalt( )
if an error is reported, then I think it's safe to assume that the program weaved between the cracks and is a 1-bit depth mac (right?)
if a report is obtained, then gestaltQuickdrawVersion is checked and if it is gestaltOriginalQD, then it's 1-bit
if it's not, then you have to deal with PixMap structures in GDHandle where you've fished out the pixelDepth Go to step 3b
Step 3a: if 1-bit
Use qd.thePort and plug your 1-bit depth gfx happily in the screen bitmap, offscreen bitmaps
Step 3b: if not 1-bit
Use GDHandle, assign it GetNextDevice (it gets more complicated if you want to plan for multiple screen, but eesh, no thanks)
get the pixel depth with:
PixMapHandle screenPMH;
short pixelDepth;
screenPMH = (**(theDevice)).gdPMap;
pixelDepth = ((**screenPMH)).pixelSize;
and make sure your 1-bit graphics gracefully insert themselves in the right spots of the higher structure color bitmaps...or ask the user to switch to monochrome mode.
Reactions: Kai Robinson
Crutch
293
228
Chicago
Cross-answering from the other thread. :)
If one just wants to check bit depth in a way that will work on all Macs, you can just check for the existence of the _GetNextDevice trap. If it doesn’t exist, you are in 1-bit mode. If it does, you can use it to get the bit depth.
