In the States here, I couldn't easily find Branson EC a year ago when I was setting up my VEVOR 30L Ultrasonic Cleaner (although perhaps I didn't do such a good job searching...). I ended up going with this which was available on Amazon:
Elmasonic 800 0102 Elma TEC Clean A1 Ultrasonic Cleaner Solution Concentrate for Electronics and Optics
https://www.amazon.com/gp/product/B0725WP9Z9/
It seems to work well although admittedly I don't have anything to compare against!
As far as tips I use distilled water with 6% cleaner solution and heat to 65 degrees C (from Elmasonic instructions). To clean boards I then do 5-9 minutes per side (longer the dirtier the board seems, pretty subjective). I then rinse by submerging in isopropyl alcohol in plastic tray to displace the water, and dry in my regular kitchen oven on a silicon baking pad, with the board raised up on a couple wooden chopsticks to let the air circulate underneath. I use the warming setting 150 degrees F for 10-15 minutes per side (longer the bigger the board). Finally I let the board sit for a day or so propped up perpendicular to a small fan blowing on it before testing it out.
I had originally been thinking I would have to change the water/solution very often, maybe every couple boards but heard from others that is not that case. I recall someone who seems to know what he's doing much more than me said he changed his when it become too cloudy to see or something like that.
Also, my cats do not like the Ultrasonic cleaner.
![Pouting cat :pouting_cat: 😾](https://cdn.jsdelivr.net/joypixels/assets/6.5/png/unicode/64/1f63e.png)
