Thanks , yes I have IPA and will do a shallow jiggle bath . I just find the idea of putting the Ana log board in the cleaner a tad radical ! Good to know the drying process is much the same, maybe just a bit longer ….If you hair dryer is getting hot enough to melt solder or even plastic, I suggest replacing it.
A hair dryer will be fine. You can also dry boards in an oven (obviously at a very low - lowest, even - setting).
If you're skittish about heat or the potential for static build up - it's understandable - air drying will obviously also do the job, just takes longer - like, days to be sure it's all gone. Find a sunny spot to hurry it along.
In any case, it's a good idea to blow out connectors and ic's with compressed air to dislodge any water that might be residing in places that might make it difficult for the water to evaporate during straight up drying. If you have IPA, using that as a quick rinse will also help dislodge any sneaky water and promote drying.
Bruce of course knows what he's doing, but yeah it's just a board and what steps you take would depend on the state of the board. That said, I don't have any specific experience with Classic AB's so take this fwiw.Thanks , yes I have IPA and will do a shallow jiggle bath . I just find the idea of putting the Ana log board in the cleaner a tad radical ! Good to know the drying process is much the same, maybe just a bit longer ….
Yes I put them through a little isopropyl bath . They look like new! Drying nicely in a warm room.I usually shake dry then hit it with ipa to expel water and leave in a warm place for at least 24 hours. This method has worked so far
