External Drive cable
T-Man
This is an external 3.5 inch drive, model number is consistent with 800K. The cable was cut off but it does work as I've tested it with the cable from a 400K external drive. I want to build a cable and have a 20 pin ribbon cable and have ordered a 19 pin male DB connector. Is this a straight through pin 1 to pin1, pin 2 to pin 2, etc cable?
I am tempted to use my floppy emu the cable as it has the right DB and flat cable connections but I don't want to ruin anything.
T-Man
I can confirm the cable on this drive can be replaced with this Apple Iic to Apple Disk II cable and it does work on a Macintosh SE.......this drive should work on both an Apple IIe and Apple IIgs, however, still haven't tried it as fairly paranoid about compatibility/damage particularly after googling information on the IIgs.
Does anyone out there have a clue as to whether it should be a problem with the Apple IIgs?
Innovative Electronics & Computing sells a lot of older cables at great prices....saved me from an afternoon pf building an Apple II duo drive cable AND they had a Commodore 128 monitor cable (to CGA). Check them out.
The IIGS uses the standard DB-19 female floppy connector as well as Apple and other disk drive controller cards for the Apple II series.
I am going to look into the pin-outs.
T-Man
Yes...I've seen some dire warnings as far as using an external from a Macintosh on the IIgs, however the unidisk is OK....but not sure now that I've changed the cable.
