Rabbit Hole Computing is proud to announce availability of mAcTX LC kits, at https://store.rabbitholecomputing.com/mAcTX-LC-p/mactx-lc-kit.htm. All orders ship from Northern California.
Our mAcTX LC PCB kits are produced and sold with permission of the creators of this public-domain resource, by 'bluesnowkitty' and 'compgeke'
This partial kit enables you to replace a failed Macintosh LC/LC II/LC III/LC 475 power supply with an ATX-based PicoPSU (or any other ATX-based power supply)
We've done the hard part and soldered down the surface-mount SOIC-8 MAX660, so you don't have to.
Here's what's Included:
- mAcTX LC Printed Circuit Board - ENIG plated
- MAX660 charge pump (voltage inverter for -5V), pre-soldered down
- 24-pin right-angle ATX connector (Molex 39-28-8240)
- 2x 10K Ohm resistors
- 2x 10uF Rubycon capacitors
- 2-pin header for power connector
- PicoPSU
- Cabling to connect mAcTX LC to your LC-based computer. This would typically be salvaged from the original power supply, in most cases.
- SPST toggle switch (only needed if remote power control is desired).
