Hi all, I can't beleive I just stumbled onto this forum today and not earlier, amazing!
I wonder if anyone can help me, I have a refburshied Power Mac G3 B&W running OS 8.6 with Rev2 board as CMD chip is 646U2-402, the two drives are 68pin SCSI connected to a Adaptec AHA-2940U2B 68pin PCI SCSI Controller Card.
What I would like to do is add an SSD so I can clone the SCSI drives via disk copy on the G3 and add the image to the SSD for backup and eventually switch the SSD as a master, replacing SCSI drives.
The two options I have is either
A: Startech IDE2SSD converter, that I need to purchase and then utilise the Ultra ATA connector with a correct IDE cable
B: Purchase an Internal SCSI connector, HPDB 68 Female to IDC 50 Female, plug that into an AztecMonsterII SCSI to SSD I got a while ago, I originally purchased the AztecMonsterII for my Quadra 800 back in 2013 and hasn't been used, taken well care of though this will be the first time.
What I would like to know is, which route would be best efficient, I feel as the board is a rev2 it should be able to handle both SCSI drives and IDE as the SSD or is it best to keep it all SCSI and see if the connector works from a 50pin to 68pin?
Also with the SSD drive, do I format it as HFS+ on the PC with a third party program and will the Mac G3 read it as a slave? Or do I need to setup an image via sheepshaver?
Thanks
Thanks
