IIsi Power Supply unknown part
  • It's #MARCHintosh 2025! Join in on the fun and post your project or play with some new stuff in our #MARCHintosh 2025 thread.
AlexMac
80
36
Bavaria
Hi all, I just received a IIsi with a massively leaky power supply. Got it more or less cleaned up and all caps desoldered. Unfortunately a part got destroyed which I cannot identify, Can someone help me where to get a replacement? Thank you so much!
AlexMac
80
36
Bavaria
Thank you so much! I just reinstalled the part and system powers up. Even a chime is coming. But sad Mac crash sound right after it and no video - any ideas? PSU seems to be ok though
  • IMG_2762.mov
AlexMac
80
36
Bavaria
More obeservations: When I pull all RAM SIMMs I am getting a chime and NO sad Mac sound. Still getting no video though. When I hold down the combination of Ctrl, CMD and Power Key I am getting yellow, green or grey video until I let the keys go...
jdmcs
TinkerDifferent Board DoP&G
89
Central Virginia
Have you re-capped the logic board? If so, you might want to inspect for shorts around the replaced capacitors, especially if you used tantalum capacitors with a shorter pad spacing than the original electrolytic capacitors.
You might also check out this video from Adrian's Digital Basement where he uses the built-in test mode that the Apple TechStep makes use of, but in a way that does not require the TechStep (or clone). This could help you narrow down where the fault is located. The TechStep supports the IIsi so it should also have the test mode Adrian is using:
(Unfortunately I have yet to have to resort to using this test mode but #MARCHintosh is upon us and I have my very own IIsi slated for a complete re-cap. I may very well find myself in the same boat...)
