IIsi Sony Power Supply Oddities
Garrett
151
South Carolina
Yes, I know it's comical the amount of threads started because of the infamous IIsi power supply. Naturally, I'm joining in the fun and creating another! Hopefully this will spark more discussion around what could be the culprit with them. Okay - here's the issue with mine: it powers on, then turns right off (most of the time).
I have done a complete recap of both the main board and daughtercard. I cleaned everything I could with a toothbrush and IPA after the recap. I then tossed it in the ultrasonic for two minutes to get the nooks 'n crannies.
During initial testing, I'd hit power on the logic board, and the PSU solenoid would click on then immediately off. After leaving it sit for a while, I tried again and it stayed on. Power cycling a few times caused the PSU to turn itself off once or twice, but was generally stable.
Given the attention that the daughtercard draws as a potential failure point, I swapped sub boards with a known working power supply. No dice. The previously working unit continued to work and my broken unit continued to power on then off right away.
Then, I turned my attention to the thermal resistor which closes during overheating, thinking that was falsely too hot to run. Completely disconnected this component - no change. Bridging it together causes shutdown (as is expected).
I then de soldered the large inductor at the corner of the board - all clean and no gunk. Ultrasonic did its job! Also removed a couple of diodes around the large 250V caps - all working well.
As a last-ditch effort, I touched up any solder joints on the rear looking slightly suspect. No change.
In summary, the intermittent issue of powering itself off is not due to the following:
  1. soft power daughtercard
  2. leaked electrolytic fluid under inductors
  3. TH101 resistor
  4. thermal switch
  5. solder joints
Still looking for ideas on what to try next. I am more than willing to parts swap between my working unit and this one to try and knock this out. It's clear to me I have at least one component inside this that's failing!
Reactions: corbinq27
This Does Not Compute
359
513
Powering on then off again sounds to me like a short somewhere; the PSU goes into protection.
The good news is that there's at least two options for replacements in development...but that's all I can say for now.
rikerjoe
250
Hey Garrett, I’m thinking through the restorations I did to a pair of IIsi PSUs to see if anything I did might be of help. For the worst of the two, I replaced a diode and resistor on the secondary side that were cooked/eaten by cap goo. I tested the rectifier connected to the heat sink to ensure it wasn’t shorted. And the daughter card - what a mess! I had to double-check the cap replacement and trace repairs for possible bridging. I also removed every component on the secondary side and thoroughly cleaned the board. Could one of the transformers be the culprit, and maybe a resistance check out of circuit comparing transformers from your good PSU might help? I’m reaching here…
