ImageWriter II Ribbon Cam Assembly Layout?
sgerstacker
I've been fighting with an ImageWriter II for a while. I realized that some of the diagrams in the service manual are confusing and seemingly out of order. This is the hex nut version.
This is the exploded view, which looks to be hex / knurled / retaining clip / washers, but the instructions are "Using small needlenose pliers, remove the retaining clip and two washers. Remove the vertical knurled nut."
If you look at the final version, it looks like the retain clip and washers are over the knurled nut.
Can someone verify which order they go in?
Also, if someone has some calipers, can you get some measurements on the washers and clip? I'm not certain the ones I have are originals either.
