IP printing from vintage Macs - a guide
patters
42
27
I still use an ancient PostScript SIMM equipped HP LaserJet 6MP. It is shared via a USB-to-IEE1284 dongle, from a Synology NAS which uses CUPS. I have a Macintosh SE/30 which now has a BlueSCSI v2 with wifi. Surely I could get the old Mac to print...
It took a crazy amount of reading, tinkering and web archive archaeology, but I have it working perfectly across various System versions - so I thought I would share my findings. 'Using a Shared OS X Printer' was a pivotal document, and pretty difficult to even find these days.
CUPS Confusion
The Synology NAS abstracts away most of the CUPS configuration and by default will share the printer using a Gutenprint driver, meaning that CUPS will rasterise the print job (very slowly). This isn't ideal if the printer has hardware level PostScript support. By doing some closer inspection of the CUPS config I could see that there were in fact two printers listed (lpstat -v, and then loptions -p for each device): the one defined in the NAS Control Panel ('usbprinter1' using Gutenprint driver), and another raw device (simply 'usbprinter' described as 'Local Raw Printer').
Sending the jobs to the raw LPR queue 'usbprinter', it turns out, will pass them directly to the printer unaltered. Lesson learned - I had been misconfiguring my own modern MacBooks to use 'usbprinter1', and not even getting the benefit of the LaserJet's PostScript SIMM which had been so hard to obtain.
System 7.5.3/7.5.5
Apparently there isn't much point in upgrading a Motorola 68k machine to 7.5.5 since most of the fixes were for PowerPC, or to add System Enablers for new Power Mac models - so I stayed at 7.5.3.
TCP/IP printing (LPR) was introduced with LaserWriter 8.5.1, which is also the latest version which can be installed on System 7.5. Install this first. To use LPR you need to create the printer using Desktop Printer Utility, not via the Chooser. However it doesn't seem to work. It claims the remote queue is unavailable when jobs are printed.
This can be fixed using elements of the LaserWriter 8.6 software (as reported on 68kmla here), but that version's Installer will not run on System 7.5. The required files (LaserWriter 8, PrintingLib, and PrintMonitor) can be extracted from the LW_8.6 Installer tomes using TomeViewer, but for convenience I have uploaded them to Macintosh Garden. The 'Before You Install' document for LaserWriter 8.6 shows that, unlike most of the software files, these three specific drivers have no OS version constraint nor CPU type restriction (many require at least 68040). Once you use these, you will notice that the upload of the job to the printer counts down the number of kilobytes, rather than counting up as before. And most importantly - it actually works! You can now directly print from all your applications, over wifi in my case.
I noticed that although it does work using MacTCP, it's very slow. Open Transport networking is much faster, and an upgrade to OT 1.3 is recommended by most Mac networking guides.
System 7.0.1-7.1
LPR printing depends on Desktop Printing, which was a System 7.5 feature, so printing directly from applications to a TCP/IP printer is not possible here. However, it's not too onerous. We can use Adobe's PSPrinter driver to print to a PostScript file, and then use LPR 1.2 to send it to the printer. I found the most convenient way to do this was to alias the printer's LPR settings file and to put that into the Apple Menu Items folder.
PSPrinter 8.3.1 is the latest version which will run on System 7.0.1. Even this is confusing because the Readme states System 7.1 but User Guide PDF states System 7. I can confirm it works on System 7.0.1. Irritatingly, the Installer expects to run from a separate volume, and expects it to be named 'PSPrinter', so I made a real floppy disk for 8.3.1 and then imaged that (made available at here at Macintosh Garden). It runs fine from that mounted image. During the installation there is a big splash screen which is too large for a compact Mac's 512x384 resolution, meaning the OK button is rendered off-screen. Press return on the keyboard to get past that. After installation pick PSPrinter in the Chooser, ignoring the AppleTalk errors. Set the type to Virtual Printer and click Setup to select your target LPR printer's PPD. The performance is perfectly good with MacTCP.
Technically for System 7.1 you could use PSPrinter 8.5.1 (re-branded to AdobePS), but that lacks the virtual printer feature so I think 8.3.1 is better for that reason.
System 6.0.7/6.0.8
The method is similar to above, but uses Adobe PSPrinter 8.2.1 which was the last version to support System 6. Download the disk image version from Macintosh Garden, not the QMS one. Use the MountImage CDEV or DiskDup Pro 1.0.3 to mount this, and then install.
Now pick PSPrinter in the Chooser ignoring the AppleTalk errors. This version does not offer the Virtual Printer feature described above, so the printer type will be generic. Now when you print you can select File instead of Printer as the destination, and print to a PostScript file before using LPR 1.2 to send it to the printer queue. Performance using MacTCP is perfectly fine. Printed fonts however, are absolutely terrible without installing the TrueType INIT, which doesn't seem to slow the machine down at all.
Essential Utilities
Closing Thoughts
I fully expected the print-to-file-then-send-to-printer method to be a clunky mess. It's not at all - it's just a couple more clicks per print, so System 7 and System 6 machines are barely disadvantaged when it comes to IP printing. Also, until now I didn't even realise that System 6 could use TrueType fonts. It's amazing what you can still accomplish with an OS from 1990 (System 6.0.7 being the first to support MacTCP).
patters
42
27
Update - I was able to build a working Adobe PSPrinter 8.2.1 Installer floppy image, by adding the missing LaserWriter 7.1.2 files to the QMS version. This makes it very easy to set up for System 6 now. I have added it to Macintosh Garden. Detail follows (moved from the main guide above).
The System 6 LPR solution was complicated by the difficulty in obtaining Adobe PSPrinter 8.2.1 which was the last version to support System 6. Until I embarked on this tinkering, the only available version of PSPrinter at Macintosh Garden was version 8.3.1, but I have now made that page a home to all the versions I could dig up.
The only surviving record of version 8.2.1 was a distribution provided for the QMS ColorScript 460 Dye Sublimation printer (looks like a blank page, but scroll down). After a considerable search I located this file, advertised for a different model (QMS PS 810). I have uploaded it to Macintosh Garden for preservation.
This QMS download contains a real Adobe Installer and Readme but some of the indicated files for System 6 are missing, and consequently the Installer will not proceed even when the volume is named as it expects. However, after some more tinkering I have been able to build a disk image with a working PSPrinter 8.2.1 Installer using the QMS files, which I have now also added to Macintosh Garden. Inspecting the Custom Install option, I could see that it was aiming to install LaserWriter 7.1.2 when targeting System 6. This LaserWriter version is included with System 7.1 (1992) so I was confident in taking the missing files (as detailed in the Readme) from PSPrinter 8.1.1 (1993) which also bundles this same LaserWriter version. I had to compress the LaserWriter file with StuffIt for it to be recognised by Installer. This could be determined from the progress messages, and was confirmed by inspecting the file 'PSPrinter Install' using ResEdit.
patters
42
27
Bonus content - if you're like me and hanging onto a perfectly good 28 year old PostScript HP laser printer and still want to use it with the latest macOS (in my case 15.5 Sequoia), then you'll be disappointed that Apple seems to have prevented use of the old monolithic HP Printers installation pkg. No matter, you can obtain it from Apple here.
Mount the dmg file by double-clicking. Now copy the pkg file inside to your Downloads folder. Then open a Terminal:
Bash:
cd ~/Downloads
pkgutil --expand HewlettPackardPrinterDrivers.pkg drivers
cd drivers/HewlettPackardPrinterDrivers.pkg
cat Payload | gunzip -dc | cpio -i
open Library/Printers/PPDs/Contents/Resources
open /Library/Printers/PPDs/Contents/Resources
Now you'll see all the individual PPDs from the driver pack (which are gzipped, no need to extract). Simply copy the PPD(s) that you need to the other opened Finder window, which is where macOS will expect them. Pretty amazing that I can use this printer all the way from a 1989 Macintosh SE/30 to a 2025 MacBook Pro M4.
