Iris Indigo - 12V rail problems
JeffC
143
91
Seattle, WA
Hi all,
I am troubleshooting an IP20 Indigo (R4400/Elan) that was working until a couple months ago. Current symptoms on power-on are:
  • Orange LED
  • No startup chime
  • No drive activity
I do get video output, and after startup I receive a “no keyboard connected” message despite a known-good keyboard being attached.
From what I have read, these symptoms are consistent with a missing or collapsed +12V rail. Measured at a drive power connector, the +12V rail is only about 2.2V.
During troubleshooting, I discovered a badly cracked solder joint on the +12V pin of the PSU-to-backplane connector. I reflowed that pin along with the neighboring connector pins. After doing so, I briefly tested the machine with only the PSU and IP20 board (minimum RAM installed) and got a green LED and startup chime. No drive, graphics board, keyboard, or display was connected during this test.
However, after powering the machine down and reassembling it later, the original symptoms returned, including ~2.2V on the +12V rail.
Additional troubleshooting performed:
  • Symptoms are identical with two different recently-known-good PSUs.
  • Both PSUs output stable +5V, +12V, and -12V when bench-tested with resistive loads.
  • Symptoms are the same in a minimum configuration (PSU + IP20 + minimum RAM only) and with graphics board/drive installed.
  • Measured approximately 2 MΩ between the +12V pin on the IP20 edge connector and the associated ground/return, suggesting no dead short on the motherboard.
  • To bypass possible backplane distribution issues, I bodged +12V and GND directly from the PSU connector to the corresponding pins on a drive power connector. This made no difference.
  • I also tested with only the PSU, backplane, and drive connected (no IP20 board installed) and still measured only ~2.2V on the +12V rail.
At this point I am fairly stumped and would appreciate any suggestions.
JeffC
143
91
Seattle, WA
Is there a broken connection inside the PSU?
I have tried with two known-good PSUs, and the symptoms are the same with either. Both PSUs also output 12V fine when bench-tested outside of the Indigo. While I can't 100% rule out a PSU issue, I would be very surprised if both PSUs failed in a way that cause the same symptoms.
JeffC
143
91
Seattle, WA
I think this is solved. I ran two test leads out of the PSU, one connected to the 12V rail, and one to GND, so I could measure actual voltage at the PSU. Sure enough the PSU was generating a good 12.3V, but I was still only getting 2.2V measured at a drive connector on the backplane. I took a close look at the PSU I was using to test, and realized I had a screw installed in one of the holes on the back. I believe the head of the screw was hitting the case and causing the PSU to not seat fully in the connector. I removed the screw and was able to get the PSU to seat fully, and then the machine booted. For the second PSU that also was not working, I think the connector is a bit weak and it really needs to be fully seated as well. It works too when fully seated.
So I think the original issue was the cracked solder joint on the PSU backplane connector. That is why after I repaired the cracked joint, the machine did work once. Then everything after that was user error. :rolleyes:
Reactions: ScutBoy and bakkus
JeffC
143
91
Seattle, WA
Yeah the PSUs in these machines are complex. My other SGI is an Indigo2 Impact, and their PSUs are known to be quite problematic. The I2 PSUs are failure-prone, and from what I have read online, essentially unrepairable. Or more accurately, no one has put the necessary time and effort into figuring out how to repair them. there are also no suitable replacements, for various reasons in am not well-versed on, an ATX PSU cannot be adapted.
ScutBoy
349
Northfield, MN USA
I have one Indigo that works fine, and another that locks up after 10 minutes or so.
If I take that one and have the front door open with a desk fan blowing on it, it runs OK. I need to try and figure out where the heat is an issue, on the graphics board or CPU board. Since I don't have a thermal camera, I'm afraid it's going to be the finger (ouch!) method for now :)
