I have a LC 550 logic board that I'm trying to get working and would appreciate any thoughts and/or advice.
It came to me looking pretty good, maybe some signs of leaking capacitors but no obvious signs of trace damage. I did test it prior to re-capping in a known working LC575 chassis: On keyboard soft-power up the front power light turned on, the fan started, the display showed a gray screen with square corners, but no start-up chime or Happy Mac icon...
I recapped the the board with no issues and cleaned it in my ultrasonic cleaner. Rinsed it with IPA, dried it in the oven at 150F for 30 minutes, then with a fan blowing on it overnight. Still no joy, and actually now I'm not even getting the gray screen, just the power light and fan turning on with soft-power on. I had the ROM chips removed while it was in the cleaner, so those have been reseated.
I tried leaving it plugged in, rear switch turned on overnight, with no change in behavior.
I've read the sound chip can be problematic on these board as its surrounded by 4 capacitors that can leak their contents under it so removing it and cleaning under it may be the next thing I try. Also could try the same with the EGRET chip...
