Looking for a Replacement PSU for an SE or SE/30?
JdM74
41
45
Georgetown TX
Greetings fellow Compact Mac Enthusiasts!
Do you have a PSU that is beyond repair due to cap damage? Looking to get that rig back up and running? You may have found your answer here!
A gentleman over on the 68kMLA forums has put together a drop-in replacement PSU for the SE and SE/30 that will fit any of the three major PSU cases used in the series -- Sony, Astec and the 'Singapore'/Hitachi.
The prototypes have been tested and look excellent. There is a plan to have them up for sale soon on eBay. Pricing is still being decided, but is rumored to be $135 + applicable shipping and taxes. Do not hold me to this number...as it is subject to change.
I'll be sure to post updates as details come available!
JdM74
41
45
Georgetown TX
Folks, Chris from 68kMLA has posted the drop-in replacement PSU on eBay!
https://www.ebay.com/itm/266898469654
He is charging $135 and will ship internationally.
I did a couple of rounds of testing for this PSU. All values taken from the same test rig [using an SE* with an internal 800k drive] at the external floppy drive connector:
First round of testing:
  • Stock SE and SE/30 [4MB RAM]
  • No boards installed
  • Spinning platter hard drive [Quantum 40MB]
  • Used an 800k disk to boot also*
Both systems -- +12V was a solid 12.05V, +5 also solid 5.00V and -12V was at -11.98V
Second round of testing:
  • Not-so-Stock SE and SE/30
  • Accelerator board installed [for the SE, one by Novy systems - 25MHz 030] and a Carrera 040 [40MHz 040] in the SE/30.
  • In the SE - 4MB RAM
  • In the SE/30 - 8MB RAM
  • Spinning platter hard drive [same as above]
Both systems -- +12V was a solid 12.03-12.05V, +5 hovered between 4.96 and 4.98V and -12V was at -11.93V
There was a return post on 68kMLA asking about voltages and a fully loaded SE/30 with 2 PDS cards. Unfortunately, I didn't have two cards to test with, just the one. However, consider the original PSU specs and the one's for the drop-in:
Original Apple PSU Specifications -- Input: 100-240VAC
Output:
+5V @ 6A
+12V Disk @ 2.1A
+12V Sweep @ 1.25A
-12V @ 0.5A
Replacement PSU Specifications -- Input: 100-240VAC
Output:
+5V @ 10A
+12V @ 5A
-12V @ 1.25A
