M0001 power sweep/video board dead
MacintoshClassic
6
Need help on how to assess this M0001 analog board.
For context; almost a year ago now this board stop working with a loud pop and accidentally turning it on without being connected to the motherboard fried some components (r45, r60, q9E, q10), which i replaced. Once everything was soldered i reassemble the computer, plug it in… absolutely nothing. Swapped in a good fuse but that didn’t change anything so the fault is something else. Attached some pics to show what it looks like currently. I know someone who could check connections with the multimeter but whats a good place to start?
SteveHere
There was a book published in 1990 called "Macintosh Repair & Upgrade Secrets" by Larry Pina. It's an amazing book with practical steps you can follow for most Compact Mac troubleshooting. It's been a big help to me many times since @ScutBoy recommended it too me. You can find scans of this book online.
Reactions: ScutBoy
ScutBoy
314
Northfield, MN USA
Pina also did a book called "The Dead Mac Scrolls" which which is a sequel to the above moving into even later machines. You will generally find both together - get them both!
Reactions: SteveHere
fred1212
129
23
In the photo it looks like you may have a solder bridge on Q10. Also some solder balls to remove
This PDF is attached in our resources section.
