Mac Plus + RGB2HDMI + Sys6 Progamming + homemade stream? yes please
Mu0n
649
606
Quebec
Did you have issues with the occasional video glitch with your RGB2HDMI? My image is rock solid on my Mac Plus, but I'll have once-per-minute video twitches on the feed I get. I'd love to compare notes with your config file if you don't mind.
I didn't solder my wires into the J8 connector of the logic board, I just jammed the exposed ends of dupont wires into the white connector and since there's not a lot of space in there, they have to make contact with the wires that are already present. I continuity tested them and they seemed very obviously solid.
jcs
66
Chicago
jcs.org
I don't think I've had any issues with that. I do notice that occasionally the Genlock LED blinks but maybe only every half hour or so.
Mu0n
649
606
Quebec
I have 2 settings file:
Under the card's root dir (this one is used, it seems):
sampling=3,3,3,3,3,3,3,0,1,0,1,0,0,0,0,0,0,1,0,0,100,256,100,256,100,256,0,256
geometry=168,6,512,342,512,342,2,2,0,0,15667200,704,5000,370,1,0,0
palette=Mono_(2_level)
output_colour=1
output_invert=2
scanline_level=0
font_size=0
num_buffers=1
Under \Profiles\6-12_BIT_RGB ( I think I got this one from the net, I didn't like its palette)
sampling=1,1,1,1,1,1,1,0,0,0,5,0,0,0,0,0,0,1,0,0,100,256,100,256,100,256,0,256
geometry=172,22,512,342,512,342,2,2,0,1,15667200,704,5000,370,1,0,0
palette=RGB
output_colour=1
output_invert=1
scanline_level=0
border_colour=7
Do you have something similar to the first one?
jcs
66
Chicago
jcs.org
I'm not sure which one it uses, profile_6-12_BIT_RGB.txt in the root of the SD card shows:
profile=Mac_Plus
saved_profile=0
The Saved_Profiles/6-12_BIT_RGB/Mac_Plus.txt file has:
sampling=1,1,1,1,1,1,1,0,6,0,5,0,0,0,0,0,0,1,0,0,100,256,100,256,100,256,0,256
geometry=172,6,512,342,512,342,1,1,0,1,15667200,704,5000,370,1,0,0
palette=Tea1002
contrast=200
output_colour=1
output_invert=1
scanline_level=0
border_colour=7
powerup_message=0
and Profiles/6-12_BIT_RGB/Mac_Plus.txt has:
palette=Tea1002
output_colour=1
output_invert=1
scanlines=1
scanline_level=0
Reactions: Mu0n
