Mac SE 30 games crashing
billbucks
40
Hi
I started playing with games on my Mac SE 30 with OS 7.5.3, 5 MB RAM, and BlueSCSI (Beyond Castle, Shufflepuck cafe...)
For some odd reasons, games sometimes crash and I have to restart the Mac.
What could be the reason ? Not enough or bad RAM ?
Can you get a photo of the errors that are being thrown up? Would help for diagnostics 😊
billbucks
40
I'm often getting a Bus error message before having to restart the Mac.
Do I need to add more RAM ?
billbucks
40
Hi
I'm using Mac OS 7.5.3 with most extensions installed. Shall I install a new OS with the minimum set of extensions ?
billbucks
40
I downloaded the games from macintoshrepository.org e.g. . shufflepuck-cafe
I installed Mode32 and enabled the 32 bits memory. I'm still had the getting the error. Cleaning the RAM simms didn't sort the issue.
I removed the 4*256k RAM to keep the 4 * 1MB RAMs and enabled the virtual memory.
With star wars, pausing the game and accessing the menu led to Error 10 (before removing the 1MB RAM, it produced a bus error).
I changed the OS to test 7.0.1 and it worked!
Does it mean I need to add more RAM to use Mac OS 7.5.3 ?
YMK
354
283
You cannot have 32-bit addressing enabled for applications that are not 32-bit clean. The machine must be in 24-bit mode.
YMK
354
283
Would the Rominator II sort the issue with its "make your system 32-bit clean" feature ?
Rominator II allows your SE/30 to operate in 32-bit addressing mode, just like Mode32. If you have a Rominator II, you don't need Mode32.
The problem is the games you're trying to run aren't 32-bit clean, and cannot be made so. Therefore, you must switch to 24-bit mode to run them.
billbucks
40
Ok thanks for the info. So I understand that I need to disable the 32 bit mode and increase my RAM to avoid games crashing if I keep Mac OS 7.5.
YMK
354
283
You have enough RAM to run those games under an older System, like 6.0.8.
You can keep System 7.5 on your hard drive and boot from a System 6 floppy when you want to play older games.
Some games just don't work with System 7 regardless of addressing mode or available memory.
billbucks
40
I installed 16MB RAM to have a total of 20MB RAM. It works well and most games run now without any error.
The only exception is Star Wars which also crashed in miniVMac on a PC so I assume it doesn't work well with 7 Mac OS as suggested.
