Macintosh II
drzeissler
Hi there,
I have a macintosh II and I bought the 256color card for it. It was very hard to find an LCD Monitor that syncs with that 256color Nubus card.
I recognized moving white lines when the SCSI bus is accessed. Where Do I have to look...could this be the gfx-card or is this something else?
It is only visible when loading files.
Thx
Doc
jasa1063
39
21
Hi there,
Thx
Doc
I have had very good luck using the follow DB15 to VGA adapter from CablesOnline to hook up to LCD monitors. The trick is finding the right switch settings to match the sync signal between the video card and LCD monitor.
drzeissler
I have 10 different adapter and you can switch them whatever you like,
you get only a picture with one certain monitor..all others fail to get a picture and the one that does works with every adapter and !every! SETTING.
