Macintosh SE/30 and Blue SCSI v2 with Pico W - Internet Woes
insanelygreat88
St. Louis, MO
Hi all,
Apologies if this is the wrong forum for this topic or if there is a topics already around this, I'm a newbie!
I have a Macintosh SE/30 with a Blue SCSI v2 with Pico W installed. Everything works great, except for internet. I have followed the instructions from the Blue SCSI website to set it up, but I can't seem to get it online. I also tried using the Wi-Fi Desk Accessory and it opens and allows me to choose a network, but when I put the password in, nothing happens. It doesn't connect. If I try it enough times, eventually the list of networks/hotspots disappears and no networks are shown.
I'm not sure what is happening, as I've tried this on my other compact Macs and it works with no issues. It's only on this SE/30.
Anybody run into this problem before or have a solution? I'd love to get the SE/30 connected to the internet.
Thank you!
EDIT:
I'm running System 7.1 and the SE/30 has 8MB of RAM.
1,535
scsi.blue
The Pico-W has a very small antenna unfortunately - distance from AP, noise, shielding, etc could all play a factor here. It sounds like everything functionally is working - you are seeing AP's (eventually) which means things are working.
There is nothing inherently different with the SE/30 in this regards from your other compact macs. I have it working happily on my SE/30. I have a 2.4Ghz "retro" access point just for my old machines on the network in my office so I can be sure to have good signal.
Garrett
108
MN, USA
Is the bluescsi.ini configured correctly? How far are you from your router? Can you post a screenshot of your MacTCP configuration window? There are a few things to get set up before it'll all work properly!
