MacSD - SCSI to SD adapter with CD audio, MIDI and fan control
YMK
408
343
MacSD is a SCSI adapter for Macs, DOS, Windows and other platforms.
It's a bus-powered device in a 3.5" drive form factor.
General features:
  • Reads up to 3.2MB/s, writes up to 2.5MB/s (PowerMac 6100, 57MHz clock speed)
  • Hard drive images
  • CD images - Data CD, audio CD, mixed mode, iso, bin + cue/toc
  • Composite images - Allows mounting of multiple floppy / volume / MiniVMac images under one SCSI ID
  • Move files from the SD card to your Mac with the Commander application
  • Overclocking options - Choose a clock speed of 33, 48 or 57 MHz
  • FAT32 filesystem for easy image transfer
  • MBR partition-mapped images for >4GB disks
  • Disc catalog allows rotating through CD images without rebooting
  • Easy firmware updates via SD card
Audio features:
  • CD audio output
    • Stereo 44100Hz at 12.45-13.28 bit resolution
    • Software volume control
  • MIDI synthesizer
    • Stereo 32000Hz at 13.75 bit resolution
    • Up to 32 voice polyphony
    • 13 drum kits
    • 128 General MIDI instruments
    • Three reverb effects
    • 3D depth effect
    • Works with Mac over SCSI and with PC as SoundBlaster wavetable daughterboard
  • MIDI routing system
    • OMS MIDI driver for Mac
    • SCSI, USB and MPU-401/DIN interfaces
    • Hanging note correction for Creative Labs cards
Fan control features:
  • Up to eight temperature sensor channels (sensors not included)
  • Up to two PWM fan control outputs
  • Fixed speed or temperature-based fan control
USB interface:
  • Serial terminal interface for monitoring and modifying parameters
  • Bidirectional MIDI interface
Performance on a PowerMac 6100 with 57MHz overclock:
MacSD ships with the Commander application, which easily moves files from the FAT32-formatted SD card, to your Mac. This is a convenient way to move downloads to older Macs without networking or emulators:
Reactions: JDW and retr01
1,982
@YMK
Sorry if this is written somewhere, but what are all the file types that your Commander app can understand?
Your screenshot only shows SIT files. But can pretty much any file be downloaded from Macintosh Garden be placed in the root (or directory of one's choice) on a properly FAT-formatted SD card, and then the user would put that SD card into MacSD on the vintage Mac, boot the vintage Mac, and then user the Commander app to select/move those files to the primary MacSD volume (and/or any connected SCSI drives)?
Reactions: YMK
YMK
408
343
Yes, any file type can be moved. Commander does not filter based on type or extension.
TT/30
25
15
California
I didn't know about the Commander and Midi applications since I don't recall those features being available when I bought mine a few years ago.
@YMK Is there any more info on the synth engine? The product page mentions it is sample based. Does it include Roland type samples like 808 drums?
Let's say someone wants to output the MIDI sound while using the MacSD in an SE/30. What ways would someone route out the sound? One thing that comes to mind is some kind of internal mixer to mix the system and MIDI audio, but that would probably be too complicated and to do it right would be like designing a sound card.
YMK
408
343
Yours must have shipped with pre-v1.0.0 firmware then. There have been many improvements since, including a significant performance increase.
Take a look through the manual. You might be interested in some of the other new features.
The synthesizer does include 808 drums, sampled from the Roland SC-55 and the Yamaha MU100. These are all of the available kits:
There's more information about the synthesizer and options in the manual. If there's anything specific you'd like to know, feel free to ask.
As for mixing MacSD's output into the SE/30's audio circuit, I haven't looked into it. It may be easier to add another audio output at the expansion slot if you have that available. If you feed the logic board audio into MacSD's CD Audio In header, it will handle the mixing.
There's latency when using MIDI over SCSI of a few hundred milliseconds. This isn't a problem for games and .mid file playback, but it could be an issue for other uses. This latency does not affect MIDI received over the expansion or USB port.
Here's a sample of the synthesizer on an LC475:
TT/30
25
15
California
Nice! I found the MIDI section further down in the manual. It makes more sense now knowing there's a separate package for the sounds that needs to be included on the SD card. This functionality is very interesting and not expected to have on a SCSI emulator. I would like to try this out sometime and need to recall how I rigged up playing the CD audio when I first tried out playing CD audio on the MacSD.
I recall I was having issues with the MacSD early on with reading images. I have had issues with SCSI2SD as well. This past August I bought a ZuluSCSI at VCF and that worked well (point being maybe my hardware is in a stable config) and somewhere in the process I also updated the MacSD firmware, so it looks like I have the latest. Besides disk image issues, I remember running into fragmentation errors and tried remaking the SD card setup multiple times.
