MDD Power Supply Recap Success
Windsor
Just a quick success story. I picked up a PowerMac G4 MDD 1.25-DP to have as my multipurpose vintage machine. It is the fastest PPC machine I've ever had. But I was a poor student when G4s and G5s were current so they were well out of my price range back then. I kept an Apple laptop, but ended up migrating to PC for my desktop.
I bought the MDD semi-local on eBay for a decent price, listed with no hard drive, does not boot. I was hoping all it needed was a drive. When I attempted to power it on, it would only make noise for a second or so, or it would only click. After poking around it for a minute, it actually powered up! I got it set up with a StarTech IDE to SATA adapter, installed OSes, and so on. It worked for a couple days, but then went back to only clicking.
I built an ATX adapter harness out of a StarTech ATX extension cable, and fought with that for a while because I accidentally omitted one pin. It seemed to boot, but I was getting no display. Seemed like maybe an issue with the ADC card with an ATX supply. But when I got my hands on a couple of my other graphics cards (non-ADC from a Sawtooth and a PCI card from a B&W), I found that those did not work either. Eventually I found my problem with the harness and everything is working again.
In the meantime I was assuming that recapping the power supply would let me work with ADC cards again, so I ordered all the caps from DigiKey. After finding my problem with the ATX setup I had renewed confidence that the machine was actually still good, there wasn't some other problem that was causing the power and display issues. So I sat down and recapped the power supply. It took me over four hours to do, but it was a success. I have a working MDD and I can actually close the case again.
Now what should I do with it?
S. Pupp
Well done! I looked at the insides of my MDD PSU, said “no way,” and backed away slowly and quietly. I got it fixed professionally, and have obtained a couple more PSU’s in case I get up the nerve to tackle them.
As far as what to do with it?
This is partial list of what I’ve done with mine (purchased new in 2004):
- Made greeting cards using Color-It! paint software
- Digitized TV shows from VHS tapes using a MiroMotion DC30 video capture card (and, earlier, a Canopus ADVC-100 Firewire capture device)
- Made DVD’s of the video captures using Bitvice (or was it Bitvise?) and I forget which DVD burning software
- Digitized my CD collection
- Accessed years of Clarisworks documents
- Played Unreal Tournament and Doom
- Hooked it up to my projector with VGA input to watch DVD’s and play the games mentioned above
It was in daily use from 2004-2018, when it started to become unreliable.
Windsor
I bought Halo for Mac when it originally came out, but I've never had a Mac fast enough to play it properly. Best I had back in the day was an 800MHz Quicksilver which was on the bottom end of the system requirements for CPU, and I don't recall what I had for a graphics card but it probably wasn't enough. This machine should do it just fine. And I'm considering getting a card from a G5 so that I can get Core Image support. I found an iLife '09 box, but it wouldn't install iMovie without a Core Image capable card. Not that I would have anything to do with iMovie even if I did get it installed...
AndrewG
really interested in the recaps !
I Just been exploring my duodoc power suppiy unit as I have about 6 these units . and persistent power supply failures . Lucky I came across this site in my search for answers cause I did suspect the caps to be the offenders in older items . Electrolytcs are voltage rated and it seems two caps might be especially vulnerable with 25V 100 Mfarad... One other here noted he replaces with 35V . In general to allow for ac. dc a 50% above rated is recommended . so some logic in placing with 35V. IM doing same as you so hope it will fix . I run a g4 cube also os9.1 with photoshop and its still a good workhorse..
Windsor
These are the parts I used for the recap, bought from Digikey. The recap took me several hours. Someday I'll get myself a vacuum desoldering tool, would have made the job a lot easier, but I did this with a spring loaded solder sucker.
IndexDigiKey Part #Manufacturer Part NumberDescriptionQuantityUnit PriceExtended Price
1​
1189-450HXW100MEFR18X25-ND450HXW100MEFR18X25CAP ALUM 100UF 20% 450V RADIAL
3​
$4.21​
$12.63​
2​
1189-1297-ND35YXJ220MCA8X11.5CAP ALUM 220UF 20% 35V RADIAL
1​
$0.46​
$0.46​
3​
478-REF0511470M025KCT-NDREF0511470M025KSERIES: REF/ CASE: 0511/ CAP: 47
3​
$0.23​
$0.69​
4​
1189-2577-ND16ZLS2200MEFC10X25CAP ALUM 2200UF 20% 16V RADIAL
1​
$1.08​
$1.08​
5​
493-6973-NDUHW0J272MPDCAP ALUM 2700UF 20% 6.3V RADIAL
1​
$1.01​
$1.01​
6​
1189-1455-ND6.3ZLH2200MEFC10X20CAP ALUM 2200UF 20% 6.3V RADIAL
2​
$0.62​
$1.24​
7​
1189-2566-ND10ZLS3300MEFC12.5X20CAP ALUM 3300UF 20% 10V RADIAL
1​
$1.21​
$1.21​
8​
493-5371-1-NDUPS1HR47MDD1TDCAP ALUM 0.47UF 20% 50V RADIAL
4​
$0.29​
$1.16​
9​
1189-4003-1-ND35ZLH470MEFCT810X16CAP ALUM 470UF 20% 35V RADIAL
1​
$0.67​
$0.67​
10​
1189-1749-ND35ZLH680MEFC10X23CAP ALUM 680UF 20% 35V RADIAL
1​
$0.83​
$0.83​
11​
1189-1232-ND25YXG100MEFC6.3X11CAP ALUM 100UF 20% 25V RADIAL
1​
$0.28​
$0.28​
12​
493-15842-NDUPS1H4R7MDDCAP ALUM 4.7UF 20% 50V RADIAL
2​
$0.28​
$0.56​
13​
1189-2560-ND10ZLS1000MEFC8X16CAP ALUM 1000UF 20% 10V RADIAL
2​
$0.60​
$1.20​
14​
1189-4215-1-ND50YXF10MEFCT15X11CAP ALUM 10UF 20% 50V RADIAL
4​
$0.26​
$1.04​
15​
1189-4057-ND16ZLK470M8X16CAP ALUM 470UF 20% 16V RADIAL
1​
$0.70​
$0.70​
Subtotal
$24.76​
