My first severely battery-bombed Classic Mac... any advice ?
iPhil64
119
79
France
Hello all,
A while ago, I had bought a very cheap non working Classic.
I opened it today, to find a very badly battery bombed machine. I haven't extracted the board yet, but think it will be outside reasonable repair, so this will be a good parts source for me.
This is the first time I have so much damage on a machine, and the board won't even slide, as it seems literally glued by corrosion.
Any advice on how to remove it without causing too much additional damage ?
The battery itself, a few capacitors, the quartz just fell of the machine as I was opening it.
The analog board, floppy, hard disk CRT and memory extension look ok, I will test them later.
iPhil64
119
79
France
Did take the motherboard out.
I already did a vinegar/toothbrush path, now in the ultrasonic cleaner (which is a bit small unfortunately). The board itself does not look that damage at first sight once all the residues are out. Anyway, I do not have a lot of hope.
Depending on how many of the custom ICs are hosed, this could be a fun project: https://github.com/kr239/Macintosh-Classic-Reloaded?tab=readme-ov-file
ooooh yes !
See the "after" picture, not sooo bad, and mostly passives on the left hand side. Worth playing :)
iPhil64
119
79
France
New board ordered. Analog board will need recap (see bottom left) at least, but not in a bad condition
How do we stop corrosion for good on the chassis ?
