I have two Macintosh SE computers, both have Sony CR-44 power supplies. I have recapped one of these supplies with a kit from Console5.
Both power supplies are exhibiting the same issue: the 12V output is measuring nearly 12.8V, which is definitely out of spec and is causing artifacts on the screen.
Meanwhile, the 5V rail is reading 5.08V…
So I discovered that there is an adjustment potentiometer in the power supply, and I tried adjusting it while under load (using an ATX extension cable). When I adjusted the power supply to 12V using this adjustment, the 5V rail was an unacceptable 4.2V. But as soon as I got 5V back into spec, 12V was was out of spec (high) again.
This seemingly indicates that I have a faulty component in the power supply that I tried to adjust. But I’m no power supply expert, and I haven’ta clue where to begin.
Also, please contain this thread to repair suggestions only. I realize that I could install an ITX power supply in the Sony CR-44 and call it done, but that’s probably outside my budget right now… especially since I have two power supplies that are both malfunctioning.
