I recently picked up a Mac Plus that had been updated with a Total Systems 68030 accelerator board. On powering it up, I get a nice clear startup chime, but no video. The floppy is toast, but I can see activity on my FloppyEmu when I have it plugged in.
I've independently tested the CRT (it has very bad burn in, but worked fine when I put it in a Plus-upgraded 512k machine I have), and the analog board (I used this machines analog board to run the previously mentioned 512k with Plus upgrade). I do get a glow in the glass behind the CRT when using the logic board with the acclerator, just no picture on the screen.
So on the surface, the analog board and CRT seem fine, but I get no video output at all. Any thoughts on things I can try? Anyone have experience with these accelerator boards.
One thing that was interesting is that when it arrived, there were 4 IC hooks connected to the analog board, 2 going to a fan mounted over the analog board, and 2 going to a box mounted behind the floppy, then a connector from that box to a connector on the accelerator board. the small box looks like it may be some sort of a power supply. I'll inspect in more details. However, I'm not entirely sure these connectors are actually connected to the correct legs on the analog board. The fan was connected to the CR23/24, and the connector to the box were connected to C25/26. Maybe these should be connected somewhere else and that is causing issues. All other connections to the analog board are standard.
Does anyone know if there are resources to the install guide for the Total Systems 68030 accelerator for the Mac Plus? I'm hoping I can use it to confirm everything is hooked up properly. I found a video showing the accelerator as well as a forum post about the same card: https://68kmla.org/bb/index.php?thr...us-with-total-systems-accelerator-board.3706/ that appears to show the IC hooks connected to the same place as mine.
Thanks for any advice you can provide!
