Parametric PGA socket
mmu_man
138
70
I saw @max1zzz had a try at OpenSCAD, to generate PGA sockets, so I helped and cleaned up the code, made it more parametric, so we can now 3D-print sockets for all those… The code is here.
max1zzz
549
Can confirm these work really well :)
Printed in PETG on my totally uncalibrated Ender V2. Ideally you need a chip in the socket when soldering as the pins may move otherwise
I did have to open up the size of the holes a tad to compensate for the resolution limit of the printer
Reactions: phunguss
max1zzz
549
I have been printing the holes at 1.8mm bottom and 2.2mm top, quite a lot bigger than the actual pin but this is partly probably down the the fact I have never really aligned my printer
Melkhior
98
I love the idea, but I have to ask: is it really cheaper in the end than just buying some preci-dip sockets from Mouser? As far as I can tell, they have stock even for more exotic configurations like the '881/'882, '030, '040 and '060...
'881/'882: 510-83-068-10-061101
'030: 510-87-128-13-041101
'040: 510-87-179-18-112101
'060: 510-83-223-18-091101
(83/87 is a difference in gold pin finish, cheapest of the two will do).
... and looking at the price of some of them, I realize for larger sockets it may be worth it after all ...
mmu_man
138
70
Oops, looks like I zapped one value in the cylinder args somewhere and it made a cone, fixed.
I added a margin slider.
Need to go back home to push it though.
Edit: fixes pushed.
mmu_man
138
70
I have so many other stuff to do that I couldn't help but add support for hollow versions with Unicode Art for the angled corners.
Melkhior
98
Well, turns out the socket for the 182 pins version (V suffix, static core, 3V3 Vcc) of the MC68040 doesn't exist at all at preci-dip... so might need to print that one! Did a PR.
Now I really need a source for those pins :)
