PowerBook 5xx USB-C PD Adapter
mmu_man
187
125
I started designing the connector years ago but never really finished, I planned on using step-down boards and designing a case, much like @PotatoFi ended up doing for the 1xx series. I was a bit reluctant to sending only 15 volts, and I'd have liked to be able to check on schematics, but I suppose it should still work, after all the battery itself can go as low as 7V, and it seems people are doing it regardless, so better do it properly…
Still a few things to tweak to facilitate the assembly but it works.
I really want to confirm from schematics/PCB, but at least testing with AAUI+VGA output, HDD, full brightness, starting Netscape and using the floppy works OK.
Note it only provides Vmain, so no charging. I'm still investigating if it's possible without extra hardware.
mmu_man
187
125
So, as discussed on MLA, and I tested it, it seems the battery is hooked directly on Vbatt without any current limiter in the laptop, so if we want to charge as well I'll have to design some PCB to add inside. I think it's possible. 🤞
So, someone confirmed using 15V Vmain without trouble for a year, I guess we're pretty safe there.
mmu_man
187
125
So, the only thing I hate more than people forcing me to published unfinished work because they are redoing what I spend nights already doing, is people wasting time doing what I already did…
Oh, and a voltmeter variant, because people love useless displays… (untested yet) (it's *NOT* a vape :p )
Needs some more margins but it works:
Reactions: Elemenoh and wottle
mmu_man
187
125
Just tested myself for the sake of it, it happily triggers overcurrent protection at 1.3A if I let it charge on a bench supply. So definitely needs some circuit to calm it down.
mmu_man
187
125
So, just confirmed on my PB520c, Vbatt is drawn almost directly to charge the battery (it drops at 11.7V), but it's disconnected when it thinks it's fully charged, so I only have to implement current limiting, not a full charge control.
Reactions: PotatoFi
